CoD2 problem.
Started by maxping, Jan 24, 2007, 19:53:27
maxping
I have just started using a TFT monitor and set the CoD2 options to the native resolution of 1280 X 1024 , Refresh at 75Hz (also tried it at 60Hz) and the Aspect ratio to "Auto".
I can play fine and it looks great, my problem starts when i close the game and enter the same server again,the settings have gone back to 1024 X 768 , refresh 60Hz and Aspect "auto".
These are the settings i used to run my CRT at , has anyone any ideas why it will not keep the first settings ?
The game still looks great at 1024 so its not a big problem i just cannot understand why it will not keep the higher settings.
TIA.
I've pondered this very question before and unfortunately i did not find the answer. But as if by magic one day, it happened to remember the settings i wanted it had and they have stuck ever since!
Sorry i can't help on this one!
maxping
Thanks i will keep entering them and my fingers crossed.  :laugh:
MoHux
Is it still looking for your old CRT? ....... have you changed the monitor drivers?  Look in 'Display' and see.
HTH
maxping
I deleted the Samsung CRT's driver the TFT didn't come with a disc and shows as plug and play .
MoHux
#5
I haven't checked, but it may pay to have a look here.
HTH  :)
Oopsy!! I see the CRT was Samsung not the new one, sorry m8.  :(
maxping
Sorted (i think) i went into the main / players / my name folder and  edited the config_mp cfg file to the settings i want and it seems to work.  ;)
MoHux
Good thinking!  Glad you got it sorted  :)
Now, don't forget, keep your head down ...........
maxping
neocr0n
Old I know but for future reference.
Adding "-w 1280 -h 1024" to the target line on the shortcut should also work.  Or launch properties if the game has that option.
Play Counter-Strike 1.6 online 6 years and counting. :(
zimmerframe
Slightly off topic but something us CoD2`ers might be interested in.
Apparently an unofficial expansion pack is being developed for CoD2.  Its call Rise of Resistance and features action for the French and Polish resistance.  Have a look at
http://www.cod2-expansion.com/index.php
If The World Didnt Suck, We'd all Fall Off
maxping
#11
Great link Zimmer its in my faves ;)
