Belkin Route
Started by David, Jan 20, 2009, 01:47:20
David
http://www.argos.co.uk/static/Product/partNumber/0621654/Trail/searchtext%3EROUTER.htm
Anyone got one of these ?I like the look,not keeen on reviews on Amazon but dont rely totally so anyone who has one I would appreciate your comments.
Desktop hardwired have 2 wirelass laptops
Reliablity etc,can get them cheaper just doing some research :fingers:
talos
Not one of those, but the next one down.  Seems reliable enough, only had to re-boot once in 11months, setup was not the easiest Ive tried, so called easy setup disk included, caused more problems than it solved, I was attracted by the lifetime guarantee which seems genuine enough but the major downside for me was the offshore customer services, an Indian call centre. Apart from that no complaints, Belkin stuff though not the cheapest, seems reliable.
                         Hope this helps :thumb:
David
Thanks Talos yes it does.I did note the offshore call centres mentioned and there isnt a lot of positive feedback on this,so I think the design seduced me.I will keep looking...... :thnks:
Kettles on Rik  ;)
I've seen a few reports of problems with Belkin routers, David, more than I've seen good reports.
David
I think I will give this one a miss.I think it was the design.I have seen another Bt 2 wire which looks ok.
[attachment deleted by admin]
We approve of 2-Wires. ;)
David
Yes I know as you know I have one this one looks slightly more up to date and it will be a lot cheaper  ;D
David
Quote from: Rik on Jan 20, 2009, 10:15:39
QuoteGet more out of your broadband with this 2wire 1701HG ADSL modem/wireless router
How would you compare this with the 2700 Rik ?
Stay with the 2700, David. :)
David
 :thnks: Thats that sorted javascript:void(0);
trophymick
The last Belkin I had used to overheat :eek4: I made a frame with a computer fan attached, that worked till I got a better one :thumb:
Mick
David
Thanks Mick.............I will stick with this one........... :thnks:
Quote from: badpianoplayer on Jan 20, 2009, 10:27:24
You know when you need a break from the computer when you start talking in JavaScript. :P :out:
I thought David always had... ;D :out:
David
QuoteI thought David always had
:tease:
David
I do to have a language unique to my historical roots.I'm a direct descendant of the the duke of Berk  ;) ;D
Not the Duke of Earl? ;)
David
Yes the,Duke,Duke,Duke,of Earl  ;D
Not a YouTube in sight. :(
