Connection problems?
Started by Danni, Jan 28, 2009, 06:23:03
Danni
I'm having problems. My 2wire has all its lights on, but my internet doesn't work. I went through the setup wizard to try and reconnect, and I get the error:
ERROR:
Unable to Access Configuration Server.
The gateway is unable to access the configuration server.
Any suggestions? All other connection bits work. I'm on my phone now, which isn't great.
Danni
It's not DNS- tried swapping to OpenDNS and even typing in known IP numbers, which didn't work.
I can ping the gateway, but nothing else. A traceroute to my server fails after the first external hop (the gateway). Is this an IDNet problem?
Danni
Since it seems anyone who can help is asleep (probably sensible) I've emailed IDNet and I just have to hope they wake up soon :)
Hi Danni
try a factory reset, the last option of this page.
You will then have to run the set up wizard again, check that you are using 528Y - 27G4 - A222 - 22BJ - B22V as the Key.
Danni
If you'd not hidden the link, I would have been able to tell it was to type into my computer, not click on my phone (I'm on my laptop now with my 3G dongle as that link didn't work on my phone). I will try that, just need to reconnect the wireless which will then kill my internet connection for a bit.
Danni
Okay, did that and now it's saying it can't connect to the dns server- it seems worse than before.
can you ping 208.67.222.222 (openDNS) ?
can you confirm you have 2 green lights at the bottom of the Router
Danni
No to pings, yes to two green lights.
Only place I can ping is the gateway (212.69.63.51)
mchunt_idnet
We are aware of a few users who cannot get traffic past our gateway which we are currently investigating.
If you haven't done so already we would suggest leaving router off for 30 minutes and the trying to reconnect. It may be that there was an earlier problem that has now resolved itself and giving the exchange time to clear the session will resolve things.
Danni
So not my fault? Okay. Just had an email saying the same :)
I best go to college, as I'm already going to be rather late (luckily they understand my need for internet access there :P). If it's not working when I get home (I'll check it when I'm at college, as I run a webserver on my home computer) I'll turn it off for 30 minutes as suggested.
Thank you both for your help :)
#11
Danni, because I got you to do a factory reset, you will eventually need to set up your router security again.
Follow this guide when you do...  http://www.idnetters.co.uk/forums/index.php?topic=8927.0
You won't be able to check the web server from College, the firewall rules will have reset too and will lock you out   :bawl:
flusk
Same problems here, can't get past the gateway. IDNet status is showing orange: "A few users may be experiencing traffic throughput problems which we are currently investigating."
So another £10 to Three mobile broadband to be able to work from home today :-(
mchunt_idnet
We have found the issue and the affected connections should be restored shortly if not already.
alexwright
All working here now.
Ta.  :D
What went wrong?
Alex.
We're going to be installing a new router later today to help spread the load of the new Central and the new 21CN Host Link. In preparation, we made changes to the OSPF routing table internally - it went a bit wrong! Sorry to all for the inconvenience.
esh
Can't get a WAN IP currently.
flusk
Yes, gone again here too.
I'm also having a lot of problems although I am currently connected. IDNet's support line is permanently engaged, any chance of an update here please? Thanks.
ducky22
Quote from: Simon_idnet on Jan 28, 2009, 09:55:19
Is it not wise to test these things prior to putting them into a production enviroment...?  ??? Or would that just be too much work for you?
Ah sorry, I missed that, thanks for the heads up Rik :thumb:
Quote from: ducky22 on Jan 28, 2009, 12:58:23
The forum is not IDNet, we're independent. If you want to complain, you'll have to talk to IDNet directly.
UPDATE:
I've had a chat with Simon, the update caused a problem meaning that all their routers had to be re-booted. This resulted in loss of connection to the world for most people, in some cases it involved a loss of PPP (me!). Things should be OK now, and Simon did not expect any repeats.
