Ping times Jan 28 onwards
Started by MarkE, Jan 28, 2009, 13:49:28
Colin Burns
It does do the trick, Dave, but I believe it also causes you to lose sync. That in itself is not a bad thing as long as you don't do it too many times consecutively, which the exchange may see as instability.
conneh
Have rebooted my router a few times today, even unplugged it and left it for a while... These are my results.
Pinging multiplay.co.uk [85.236.96.22] with 32 bytes of data:
Reply from 85.236.96.22: bytes=32 time=163ms TTL=124
Reply from 85.236.96.22: bytes=32 time=159ms TTL=124
Request timed out.
Reply from 85.236.96.22: bytes=32 time=141ms TTL=124
Ping statistics for 85.236.96.22:
   Packets: Sent = 4, Received = 3, Lost = 1 (25% loss),
   Minimum = 141ms, Maximum = 163ms, Average = 154ms
:thumbd:
You need to talk to IDNet, then, they can manually move you to a different pipe.
trophymick
This is about normal for me at the moment, not much variation. (except for a total loss of service :whistle:) I'm happy with it, considering my location :thumb:
Mick
davej99
Quote from: Sebby on Feb 03, 2009, 17:15:16
and Rik re Netgear rebooting.
Sync seems to hold, at least the green light stays on and "Show Stats" polling remains steady. But I have an oddball DG834GSPv3 Branson special.
In that case, all bets are off. :D
davej99
Quote from: Rik on Feb 03, 2009, 17:27:47
Are you laughing at my oddball?
No, at the thought of betting on a Netgear.  ;D
Aaron
Odd but rebooting the router fixed it, despite connecting to the same gateway as before. Pings are good now :)
Same gateway, different central. ;)
DarkStar
Opened up connection status on my Netgear and Disconnected, waited 10secs or so and then Connected. Result below:
Ian
[attachment deleted by admin]
Ian
Is that about normal for you, Ian? That's similar to what happened to me, though I average around 24ms.
Mine was similar when I got home, rebooted the router,ping rates down nicely but still seeing a great variation in individual ping times which I presume is down to congestion.
Possible, Steve. I've got a few spikes now, but nothing untoward.
DarkStar
Quote from: Rik on Feb 03, 2009, 18:29:13
That is low for me, until this week I had never seen pings below 60>80. Tracert below
C:\Documents and Settings\Owner>tracert idnet.net
Tracing route to idnet.net [212.69.36.10]
over a maximum of 30 hops:
 1     1 ms    <1 ms    <1 ms  192.168.0.1
 2    38 ms   122 ms   121 ms  telehouse-gw2-lo2.idnet.net [212.69.63.55]
 3    36 ms    37 ms    36 ms  telehouse-gw3-g0-1-400.idnet.net [212.69.63.243]
 4    37 ms    36 ms    36 ms  redbus-gw2-g0-1-331.idnet.net [212.69.63.5]
 5    36 ms    37 ms    36 ms  redbus-gw1-fa2-0-300.idnet.net [212.69.63.225]
 6    35 ms    35 ms    36 ms  www.idnet.net [212.69.36.10]
Speed is also back to normal - 200>250mbps. It was a quarter of that this afternoon.
Ian
Ian
Sounds like you've moved off the congested central. :)
DarkStar
Quote from: Rik on Feb 03, 2009, 18:37:23
Good, I just hope it stays this way
Ian
Ian
davej99
When I was with a centrally challenged ISP, we used to log on, check ping, log off, log on, check ping, etc till we got a central that was reasonable. One smart guy automated the process and eventually we all used the routine. I guess BT round robin the logons among an ISP's centrals.
I posted some poor ping times here,I have deleted them as I forgot the WHS was running utorrent :blush:
Philip
a lot better since my router reboot
C:\Users\Philip>ping www.idnet.net
Reply from 212.69.36.10: bytes=32 time=32ms TTL=59
Reply from 212.69.36.10: bytes=32 time=31ms TTL=59
Reply from 212.69.36.10: bytes=32 time=29ms TTL=59
    Minimum = 29ms, Maximum = 32ms, Average = 30ms
C:\Users\Philip>
C:\Users\Philip>ping bbc.co.uk
Pinging bbc.co.uk [212.58.224.138] with 32 bytes of data:
Reply from 212.58.224.138: bytes=32 time=35ms TTL=121
Reply from 212.58.224.138: bytes=32 time=30ms TTL=121
Reply from 212.58.224.138: bytes=32 time=40ms TTL=121
Reply from 212.58.224.138: bytes=32 time=29ms TTL=121
Ping statistics for 212.58.224.138:
    Minimum = 29ms, Maximum = 40ms, Average = 33ms
C:\Users\Philip>
Quote from: davej99 on Feb 03, 2009, 19:18:19
I think I know which ISP you are talking about as I was once with them too. ;)
davej99
If that were true, it would be virgin on the ridiculous.
Here's mine, after router reboot:
Reply from 212.69.36.10: bytes=32 time=34ms TTL=59
Reply from 212.69.36.10: bytes=32 time=35ms TTL=59
    Minimum = 34ms, Maximum = 35ms, Average = 34ms
C:\Documents and Settings\Simon>ping bbc.co.uk
Reply from 212.58.224.138: bytes=32 time=33ms TTL=121
Reply from 212.58.224.138: bytes=32 time=32ms TTL=121
    Minimum = 32ms, Maximum = 35ms, Average = 33ms
