Ping times Jan 28 onwards
Started by MarkE, Jan 28, 2009, 13:49:28
David
C:\Users\David>ping idnet.net
Reply from 212.69.36.10: bytes=32 time=12ms TTL=59
Reply from 212.69.36.10: bytes=32 time=14ms TTL=59
    Minimum = 12ms, Maximum = 14ms, Average = 12ms
Can't complain at them.  :thumb:
David
 :thumb: Thanks Rik.....
Jusut popping out speak soon  :thumb:
I suppose he had to go out at some point!  ;D
David
drummer
Thanks for your reply Simon.  I guess I expected to see updates in Service Announcements but as it's not really a gripe, I'll say no more.
No specific problems, it's just that I didn't want to unnecessarily bombard y'all with my ping stats as I'm sure you've better things to do with your time.  Just thought I'd missed a request to do so is all.
Anyway, switched the router off for about ten minutes and seems to have done the trick.  :thumb:
[attachment deleted by admin]
That looks much healthier.  :thumb:
brizo
Hi,
Wonder if you could help me as I'm new to all this!
Traceroute has started ...
traceroute to www.idnet.net (212.69.36.10), 64 hops max, 40 byte packets
1  192.168.0.1 (192.168.0.1)  2.613 ms  25.384 ms  26.131 ms
telehouse-gw2-lo2.idnet.net (212.69.63.55)  103.130 ms  235.164 ms  111.856 ms
telehouse-gw3-g0-1-400.idnet.net (212.69.63.243)  112.085 ms  191.261 ms  118.504 ms
redbus-gw2-g0-1-331.idnet.net (212.69.63.5)  117.809 ms  138.242 ms  85.237 ms
redbus-gw1-fa2-0-300.idnet.net (212.69.63.225)  54.408 ms  53.422 ms  67.491 ms
6  * * *
7  * * *
8  * * *
9  * * *
10  * * *
11  * * *
12  * * *
13  * * *
14  * * *
15  * * *
16  * * *
17  * * *
18  * *
and so on.
Have I got a problem here?
Cheers.
Not necessarily. Try pinging instead, better, ping the IDNet name server, ie hit Start > Run > then type CMD. When the window appears, type ping 212.69.40.3 -n 10. See what that yields.
brizo
Thanks for your time Rik, by the way I'm using an iMac!
Ping has started ...
PING 212.69.40.3 (212.69.40.3): 56 data bytes
64 bytes from 212.69.40.3: icmp_seq=0 ttl=61 time=101.175 ms
64 bytes from 212.69.40.3: icmp_seq=1 ttl=61 time=107.481 ms
64 bytes from 212.69.40.3: icmp_seq=2 ttl=61 time=125.928 ms
64 bytes from 212.69.40.3: icmp_seq=3 ttl=61 time=201.057 ms
64 bytes from 212.69.40.3: icmp_seq=4 ttl=61 time=162.766 ms
64 bytes from 212.69.40.3: icmp_seq=5 ttl=61 time=159.334 ms
64 bytes from 212.69.40.3: icmp_seq=6 ttl=61 time=150.200 ms
64 bytes from 212.69.40.3: icmp_seq=7 ttl=61 time=139.882 ms
64 bytes from 212.69.40.3: icmp_seq=8 ttl=61 time=163.594 ms
64 bytes from 212.69.40.3: icmp_seq=9 ttl=61 time=155.354 ms
--- 212.69.40.3 ping statistics ---
10 packets transmitted, 10 packets received, 0% packet loss
round-trip min/avg/max/stddev = 101.175/146.677/201.057/27.989 ms
Doesn't look very good!  :(
Sorry, I kind of assume Windows until firmly corrected. :)
That doesn't look good. :( Try re-booting your router. There's been a problem with the new central becoming congested on half its capacity, while the other half remains almost empty. Hopefully, a re-boot will move you, if not, let support know and they can do it manually for you.
Similar to mine I used to be between 15-20ms,rebooting the router x3 has made no difference today, I will check with support during office hours.
Pinging 212.69.40.3 with 32 bytes of data:
Reply from 212.69.40.3: bytes=32 time=130ms TTL=61
Reply from 212.69.40.3: bytes=32 time=121ms TTL=61
Reply from 212.69.40.3: bytes=32 time=119ms TTL=61
Reply from 212.69.40.3: bytes=32 time=103ms TTL=61
Reply from 212.69.40.3: bytes=32 time=115ms TTL=61
Reply from 212.69.40.3: bytes=32 time=134ms TTL=61
Reply from 212.69.40.3: bytes=32 time=91ms TTL=61
Reply from 212.69.40.3: bytes=32 time=106ms TTL=61
Reply from 212.69.40.3: bytes=32 time=136ms TTL=61
Reply from 212.69.40.3: bytes=32 time=190ms TTL=61
Ping statistics for 212.69.40.3:
   Packets: Sent = 10, Received = 10, Lost = 0 (0% loss),
   Minimum = 91ms, Maximum = 190ms, Average = 124ms
IDNet are monitoring, Steve, but obviously the more information the better.
brizo
Cheers Rik!
Looks better!!!
64 bytes from 212.69.40.3: icmp_seq=0 ttl=61 time=43.192 ms
64 bytes from 212.69.40.3: icmp_seq=1 ttl=61 time=43.496 ms
64 bytes from 212.69.40.3: icmp_seq=2 ttl=61 time=42.706 ms
64 bytes from 212.69.40.3: icmp_seq=3 ttl=61 time=42.134 ms
64 bytes from 212.69.40.3: icmp_seq=4 ttl=61 time=44.778 ms
64 bytes from 212.69.40.3: icmp_seq=5 ttl=61 time=46.913 ms
64 bytes from 212.69.40.3: icmp_seq=6 ttl=61 time=43.469 ms
64 bytes from 212.69.40.3: icmp_seq=7 ttl=61 time=41.832 ms
64 bytes from 212.69.40.3: icmp_seq=8 ttl=61 time=43.332 ms
64 bytes from 212.69.40.3: icmp_seq=9 ttl=61 time=44.667 ms
round-trip min/avg/max/stddev = 41.832/43.652/46.913/1.408 ms
Still don't get to the end of the traceroute, though. Do you know the reason for this? I also tried www.bbc.co.uk and the same thing happens!
traceroute to 212.69.36.10 (212.69.36.10), 64 hops max, 40 byte packets
1  192.168.0.1 (192.168.0.1)  2.814 ms  20.693 ms  1.683 ms
telehouse-gw2-lo2.idnet.net (212.69.63.55)  61.498 ms  42.861 ms  128.073 ms
telehouse-gw3-g0-1-400.idnet.net (212.69.63.243)  82.714 ms  404.530 ms  86.996 ms
redbus-gw2-g0-1-331.idnet.net (212.69.63.5)  44.590 ms  42.960 ms  74.636 ms
redbus-gw1-fa2-0-300.idnet.net (212.69.63.225)  50.920 ms  54.718 ms  54.561 ms
6  * * *
7  * * *
Could just be routers giving low priority to ping traffic, or being heavily loaded. I've noticed, of late, that pinging www.bbc.co.uk times out, while pinging bbc.co.uk works.  :dunno:
It works for me to IDNet, but the BBC is timing out right now:
tracert www.idnet.net
over a maximum of 30 hops:
  1     1 ms    <1 ms     1 ms  home [192.168.1.254]
  2    23 ms    25 ms    61 ms  telehouse-gw2-lo2.idnet.net [212.69.63.55]
  3    27 ms    25 ms    23 ms  telehouse-gw3-g0-1-400.idnet.net [212.69.63.243]
  4    25 ms    27 ms    27 ms  redbus-gw2-g0-1-331.idnet.net [212.69.63.5]
  5    23 ms    25 ms    25 ms  redbus-gw1-fa2-0-300.idnet.net [212.69.63.225]
  6    25 ms    23 ms    25 ms  www.idnet.net [212.69.36.10]
Trace complete.
tracert www.bbc.co.uk
Tracing route to www.bbc.net.uk [212.58.251.195]
  1    <1 ms     1 ms     1 ms  home [192.168.1.254]
  2    25 ms    25 ms    25 ms  telehouse-gw2-lo2.idnet.net [212.69.63.55]
  3    25 ms    23 ms    23 ms  telehouse-gw3-g0-1-400.idnet.net [212.69.63.243]
  4    26 ms    21 ms    23 ms  rt-lonap-a.thdo.bbc.co.uk [193.203.5.90]
  5    26 ms    25 ms    23 ms  212.58.238.129
  6    21 ms    23 ms    27 ms  212.58.239.58
  7     *        *        *     Request timed out.
brizo
Thanks Rik.
Out of interest, I tried a speed test.
Date   11/02/09 18:16:04
Speed Down   3062.98 Kbps ( 3 Mbps )
Speed Up   373.18 Kbps ( 0.4 Mbps )
Port   8095
Server   speedtest1.thinkbroadband.com
How bad is that  :shake: In the good old days, I'd get 6.5 Mbps!
Mmmmm, I think I'll have a beer.
Can't really say whether it's good or bad, because it's missing the vital profile information. Can you try a BT test?
brizo
Had to look up the FAQ's to find out how to do it!
    Your DSL connection rate: 8128 kbps(DOWN-STREAM),  448 kbps(UP-STREAM)
    Actual IP throughput achieved during the test was - 6160 kbps
It certainly looks better.
Sorry, I should have said.  :blush:
That looks OK, not quite as good as it might, but at this time of night, I'd expect to see any exchange congestion taking its toll. If you get a chance to run one in the morning, that would be a useful comparison. :)
brizo
Will do. I'll keep an eye on things.
And thanks for all your help  ;D
still getting high pings and dns problems! another week of no xbox playing :(
David
Hi Paul see the help section
