2700 router stats access
Started by David, Feb 01, 2009, 19:59:48
David
I cant get my stats,when I use Kitz it shows no page available or times out ? anyone know the reason.
I have the 2 wire which is listed.
could get them when I used my netgear  ???
Are you trying to log into the router, David?
David
Yes,why is this wrong ? I tried wireless I tried wired but no luck  :shake:
To be honest I just want to do it Im not troubled by stats why should I be Im happy as Larry I would just like to be able to perform this task and cant  :shake:
David
That turned my screen RED Rik  :eek4:
What firmware are you using? Try just going to http://192.168.1.254.
David
Up
Current Rate:       7008 kbs       448 kbs
Max Rate:       7088 kbs       1080 kbs
Current Connection:
   Current Noise Margin:       6.0 dB       25.0 dB
   Current Attenuation:       42.4 dB       22.0 dB
   Current Output Power:       19.7 dBm       12.1 dBm
ATM       Cells       Errors       %
Transmit:       10411566       0       0
Receive:       109365427       0       0
IP       Bytes       Packets       Errors       %
Transmit:       53371035       307240       0       0
Receive:       501713560       459306       0       0
You are clever I have been trying to do this for months  :karma:
David
QuoteWhat firmware are you using? Try just going to
God knows,you know me Rik,by the look of things I had the wrong page number  :thumb:
What do the stats look like  ;)
They look fine, maybe a slightly slower sync than I would expect for that attenuation, but nothing significant.
David
 :thnks: For that appreciated,tried so many times to get into this,googled until my fingers ached   ;D
Ask first, Google second. ;)
David
 :blush: I dint want to become a burden son  ;D
All the info was at your finger tips in the help section  :D
David
What our help section Glenn?
David
 :clever: :hehe: I really didnt see this Glenn
:dig: :karma: for the lesson  :blush:
Just one point I always thought that this page was for Idnet and not for routers (I will one day learn)
You learn something new everyday, David. :)
