I dont want to format it but.. [badly infected system]
Started by mrapoc, Mar 02, 2009, 21:26:23
mrapoc
I have a laptop to fix at the moment and its not letting me do anything.
It freezes up the start bar or msconfig almost straight away, or when i try to apply settings (turn everythin off in msconfig for example)
Safe mode scan with super antispyware does detect stuff such as antivirus 2008 but it needs to reboot..which obviously wont work :(
Ideas?
Thanks guys
mrapoc
Malwarebytes +1, I use it at work, a great piece of software
vitriol
I know its not popular with some but Avast Antivirus allows boot time scans. Might be worth a try if you can install it in safe mode.
mrapoc
But is it likely to get all it needs in safe mode?
we shall see
Stupid question, but have you tried msconfig from within Safe Mode?
mrapoc
Yes but it was still unearthly slow when booted (10 mins for my computer to show..)
So i backed everything up in safe mode and have proceeded to format/install xp (in turkish lol)
To prevent this happening again I think I shall put avira antivirus on (more agressive than eset so less chance of infection) and immunization from spyware blaster & spybot s&d
mrapoc
Formatted and its works ok now
She said she had clicked an email and poof!
So i assume it was some nasty which managed to pretty much take it over
Quote from: mrapoc on Mar 03, 2009, 22:49:30
Best cure for that, Sam, is to hide all the email clients. ;D
When do we get the commission payments? ;D
