My speed is dropping
Started by David, Mar 07, 2009, 14:16:27
David
After enjoying an solid speed for some time I have notice that my speed is slowly diminishing and the line profile is also wrong or at least different from what I enjoyed for some time
    Your DSL connection rate: 6400 kbps(DOWN-STREAM),  448 kbps(UP-STREAM)
    IP profile for your line is - 4500 kbps
    Actual IP throughput achieved during the test was - 4166 kbps
This was todays test
This was last weeks
    Your DSL connection rate: 5888 kbps(DOWN-STREAM),  448 kbps(UP-STREAM)
    IP profile for your line is - 5000 kbps
    Actual IP throughput achieved during the test was - 4666 kbps
5653.13
5453.33
Now its 4166
Why would the profile gone down ?
You've had the connection drop and reconnect at a slower speed, David.
David
Will it recover Rik? I recall my profile was stuck a while ago
The profile will recover if your line remains stable for 3-5 days. It might be worth running Routerstats to monitor the drops.
David
Just turning on telnet to carry this out by the looks of thing s this is the way with the router Im using  :fingers:
What did you used to sync at, David?
David
5.5 is the norm Sebby
    Your DSL connection rate: 6112 kbps(DOWN-STREAM),  448 kbps(UP-STREAM)
    Actual IP throughput achieved during the test was - 4175 kbps
I realise its still faster than some but cant figure why it is steadily (seemingly dropping )
Looks like you've had a resync today as well. Have you changed anything recently?
David
I have today changed router Steve to see if this solves anything
J!ll
I think as Rik said routerstats monitoring will give you an indication of any noise bursts interrupting you connection.
Is this since you've changed to the 2700, David?
David
I was on netgear but today reinstated the 2700 to see if this helps Simon
Well, you know I'm on expert, but you may need to regain some stability by leaving things be for a few days, then it may hopefully improve.  :)
David
Yes,thats what I thought Simon.I have only just changed it over as you can tell by the further drop but will see how it goes  :fingers:
The sync has certainly improved. As for stability, you'll have to see. :)
David
Den
In the morning about 9.00am (Sunday) turn the power off to your router leave it for anout 5mins then turn it on again. This is usually the best time to do this and hopefully will turn in a higher DSL connection and if you hold that for a few days your profile will go up.  ;D
Mr Music Man.
David
Quote from: Den on Mar 07, 2009, 20:18:59
He will be at the early morning service. I hope anyway ;)
