Forum default theme
Started by Ray, Mar 09, 2009, 11:39:05
I've just noticed something with some of the links on the default Idnetters theme, when I hover my mouse over the text links for New Topic, Reply, Mark as Read etc. instead of the text becoming underlined the line appears above the text is this correct or is there a problem with the code? All the other links seem to work correctly in that they appear underlined when you hover the mouse over them.
Can't say I've noticed, Ray, and I can't see them from my phone, but will check it out later.
Let me change themes and check, Ray.
It is as you say, Ray. Whether it's by design or error I don't know.
Quote from: Rik on Mar 09, 2009, 11:47:13
Thanks, Rik, does seem strange though I've not seen it done that way before if it's by design.
I suppose there's no reason not too, and it is clearer away from the blue background.  :dunno:
Quote from: Rik on Mar 09, 2009, 12:01:32
This is true, Rik.  :)
