Outage
Started by Moonshine, Apr 07, 2009, 15:58:09
If you feel the need, then power it down, Moonshine. However, first look at the logs and indicator lights, to see if you can diagnose the state at the time.
See if you can find your router here then follow the instructions to extract the stats.
Moonshine
Is this what I should be looking at???
Sorry for logging off every few secs, then coming back.....keep having to check the dinner!
Item   Downstream   Upstream   Unit
SNR Margin   6   22   dB
Line Attenuation   51   29   dB
Data Rate   3040   448   kbps
As they stand they look ok I think ??? If you were repeatedly dropping connection I think your downstream margin would have been raised by the BT software but its at the default of 6db. Could you do a BT speedtest @http://speedtester.bt.com/ that will show your IP profile. If you've been dropping sync you IP profile will not be related to current sync.
Moonshine
These are the results from the BT speedtest:-
    Your DSL connection rate: 3040 kbps(DOWN-STREAM),  448 kbps(UP-STREAM)
    Actual IP throughput achieved during the test was - 2482 kbps
Things look okay. The sync is perhaps a little low, which suggests possible noise pickup. For now it's probably worth leaving things as they are, but next time you lose connection, let us have a look at the log. :)
Moonshine
Will do.  Thank you everyone  :)
Odd that the profile is higher than the sync though...
I had a stuck high profile for a while, they are rare though...
