Latency issues
Started by Moley, May 07, 2009, 20:37:06
Sluggish afternoon connected via .net pings to www.idnet.net at around 70ms cured by a router reboot and back down to 20ms, not seen this for a while.
Same here, for the past two days my pings have 'gone out' from a 23ms average to a 31ms average, Steve.
vitriol
Pings atm for me are a little increased 60ms. Normally they around 22ms.
It might be worth trying a router reboot Vit, though I'd probably leave it till morning for the best speed.
A steady 23-25ms to idnet.com for me at the moment.
So not widespread, probably not geographical...  :dunno:
Mine have stayed low since the reboot.I am not worried about the time of day due to presence of full sync and 15db margin.
You can go right off some people...  ;D
edit - we need the negative karma to come back!  :evil:
We'll just pour it down Steve's line. ;D
 :rofl:
In the recent past when we had balancing issues and the pings started creep upwards my throughput tended to fall as well, this was not the case today plus as I said the pings have remained low since the router reboot.
My balancing issues tend to come after many pints of beer of have consumed!
:lol:
It doesn't take many for me.  ;D
vitriol
Quote from: Rik on May 15, 2009, 17:13:34
Sorted
Reply from 212.69.36.10: bytes=32 time=22ms TTL=59
    Minimum = 22ms, Maximum = 22ms, Average = 22ms
It makes you wonder what happens in the process, doesn't it. IOW, is it the router or the connection?
vitriol
Not sure, dont have the time to start digging really.
Mohux_Jnr
#116
Maybe someone can enlighten me as to why we constantly now have to reboot our routers daily in order to reset an acceptable ping. I never had to do this pre-downgrade ( poor humour ). To say it is getting tiresome would be an understatement, it normally starts around 4pm and this time of day is definately the worse although recently it has continued through the evening sometimes requiring 3/4 reboots.
Is this likely to be sorted?, speaking for my connection the ping times have never been stable since the upgrade, and this evening has just about killed my patience waiting for a resolution.
Reply from 212.69.36.10: bytes=32 time=121ms TTL=59
Reply from 212.69.36.10: bytes=32 time=148ms TTL=59
Reply from 212.69.36.10: bytes=32 time=164ms TTL=59
Reply from 212.69.36.10: bytes=32 time=127ms TTL=59
    Minimum = 121ms, Maximum = 164ms, Average = 140ms
Rebooted.........no change, rebooted for a second time and the pings are back to what I pray for :blush:, but I can guarantee after an hour of gameplay it will require another reboot?.
Reply from 212.69.36.10: bytes=32 time=17ms TTL=59
Reply from 212.69.36.10: bytes=32 time=15ms TTL=59
Reply from 212.69.36.10: bytes=32 time=16ms TTL=59
    Minimum = 15ms, Maximum = 17ms, Average = 15ms
I can't enlighten you but I will agree that for me towards the end of last week my ping times were elevated to www.idnet.net @70ms this was cured by a reboot to 16 -25 ms. Today they've been around 35-40ms certainly not as good as they have been over the past few months.
All I can suggest is that you get in touch with IDNet and let them know what is happening, so that they can look into it.
Quote from: Mohux_Jnr on May 19, 2009, 21:25:47
Most of us don't, Mo. I got hit by poor pings last Thursday, a reboot cured it and they've been fine since. My router had been 'up' for 35 days when I rebooted, and that was the first ping problem I'd seen since February, I think. Some people are having issues, but it's a relatively small number as best I can judge. As Sebby says, you really need to talk to IDNet so that they can check your line.
golden
My ping is stable but exactly 10-15ms higher than yesterday and the previous months.  ???
Have you tried re-booting your router?
My pings seem 20 ms higher, Rik. My router was rebooted about 5 days ago ish they are for idnet, 41ms and for bbc.co.uk 41ms  also.
Spoke to support and they have no idea why a reboot would lower your pings in fact it shouldn't make any difference I was told  ??? Oh well, it may all change again in a day or two  :)
I don't understand why it often works, Gary, the only half-logical explanation I can come up with is that the new connection is routed differently.
