Strange thing just happened
Started by Noreen, May 22, 2009, 18:26:23
Noreen
I lost my internet connection, the LAN light on my Netgear router suddenly went out. I fiddled around and found that the light went on and off when I put pressure on the plug into the computer. Luckily I had a spare cable left over from a previous router so I changed them over and the connection is now firm as is the LAN light. I assume that a loose connection must have developed in the plug or cable, what I can't understand is how can this happen in a plug and cable that's never moved!
It was just feeling lonely and wanted some attention, Noreen. Eerily, I had a power supply fail on my router last night at around this time. Maybe we should start to worry? ;)
Could be. Whose turn tomorrow, I wonder?  :D
Noreen
I've had an idea about this. There is an exhaust for a fan near the socket and it seems possible that the LAN plug may get warm from it and then cool down constantly, perhaps over time a connection failed because of this. Possible?
I'd say that's possible. Still, it's a strange one nonetheless.
Noreen
I've been keeping an eye on it and the plug barely gets warm so I'm probably wrong. ;D
Plastics do 'dry out' over time.
Noreen
The previous cable lasted quite a long time but I intend getting a spare one just in case. ;D
I have cupboards of spares, I'm terrible like that. :)
It's amazing how many cables are accumulated over the years. :)
I still have some serial cables, Seb, and no doubt a few parallel printer cables too.
wecpcs
Quote from: Rik on May 23, 2009, 15:14:07
I have still got about 30 ATA33 IDE cables from my old shop business. I don't no why I bother keeping them really as they are of no use now, even for ROM drives which require ATA66/100/133 cables. I might have a clearout one day.
You know that the minute you dispose of them, someone will phone you asking if you have any. ;)
That's why I don't throw any cables away; I always think they'll come in handy one day!
I just know I've got an old SCSI cable and terminator tucked away somewhere...  ;D
Noreen
I bought a new cable this afternoon and replaced the other one and it's probably an illusion but the Internet seems faster. :)
It could be, Noreen, if the other cable was picking up some noise.
Noreen
The previous one was Cat 5 (which meant nothing to me) and I found later that the new one was Cat 6. I was worried that I'd bought the wrong thing so did some googling about it and found that the Cat 6 was newer and better for noise reduction. All double Dutch to me but seems to work. ;D
In order of 'quality', Noreen, it's Cat5, 5e then 6. Cat6 is good for 1Gb links and best for noise reduction.
Noreen
So you think that it could be possible that it's improved things then? I'm keeping the previous Cat 5 as a spare.
It's unlikely, but stranger things have happened. I tend to use the highest spec cables that I can get, as they will have plenty of headroom for faster traffic.
Cat6 is best for longer runs. It probably wouldn't give any gains at a short length, but I won't say it's impossible. :)
