page errors
Started by Baz, May 28, 2009, 09:13:39
just got a few page error faults over the last 5/10 mins there, couldnt get anything at all even after a reboot
anyone else?
No problems here, Baz, what's the router log showing?
nothing Rik.just had a look and normal log
Sun, 2009-05-24 01:00:01 - Send E-mail Success!
Sun, 2009-05-24 11:23:18 - Administrator login successful - IP:192.xxx.x.x
Mon, 2009-05-25 11:01:53 - Administrator login successful - IP:192.xxx.x.x
Mon, 2009-05-25 12:02:40 - Administrator login successful - IP:192.xxx.x.x
Mon, 2009-05-25 19:19:55 - Administrator login successful - IP:192.xxx.x.x
Tue, 2009-05-26 10:16:12 - Send out NTP request to 158.43.192.66
Tue, 2009-05-26 10:16:11 - Receive NTP Reply from 158.43.192.66
Thu, 2009-05-28 09:08:16 - Administrator login successful - IP:192.xxx.x.x
even just a page refresh gave an error, all lights ok on router too.seems faster now though  :dunno:
Has the sync speed changed?
no all looks fine
ADSL Link     Downstream     Upstream
Connection Speed    8128 kbps    448 kbps
Line Attenuation    36.0 db    18.0 db
Noise Margin    8.2 db    23.0 db
All I can suggest is that you give support a call, Baz, and they can look at the line for you.
ok will keep an eye on it too Rik.Thanks
Strange, the log doesn't reveal anything. :dunno:
Later Netgear firmware stopped recording re-syncs, Seb.
Quote from: Rik on May 28, 2009, 09:35:34
I had a nightmare with the Latest DG834N Firmware multiple SSID's sounds great timed wifi is great so its off when you do not need it, but when you add encryption and you cant log onto the damn thing as it does not broadcast its SSID when set to....Grrrrrrr reverted back to the previous, such a shame as the new features were great
I wonder who came up with that great idea. ::)
I really don't know, I reported it as a bug, but they said it was a 'feature'.  ::)
Ah, the old bug = feature excuse. ;D
 ;D
Yes, it's a common wriggle, isn't it. :)
Quote from: Sebby on May 28, 2009, 12:12:59
Well Microsoft have been pulling that one for years so its open season now Sebby  ::)
Dopamine
Quote from: Baz on May 28, 2009, 09:13:39
anyone else?
By page errors, do you mean page not found? I've been having slow look-up problems on and off all afternoon, so just came to the forum to check whether anyone else is experiencing the same. I changed one PC to OpenDNS and the problem went away, but remains intermittently for my IDNet DNS machines.
yes it was page not found errors or what ever firefox calls it
