WBC - successful connections
Started by Rik, May 31, 2009, 11:59:52
As an adjunct to the problems thread, it will help build the 'database' of what routers work if people who connect successfully could post in this thread with details of their router, firmware and, if you can identify it, the make of MSAN that you are connected to.
Thanks. :)
David
You and I have the same Rik and the details I wouldnt know where to look  :blush:
Country: {0xB5} Vendor: {TSTC} Specific: {0x00}
Is that it?
That's it. TSTC is Texas Instruments.
OK, still not sure what it actually means, though.  Could it be that Alactel work and Texas don't, or vice versa?
ATM, it doesn't mean too much, as we don't know of any problems with DSLAMs. As people connect to WBC, that will tell us the MSANs that work with a specific router.
David
Broadband Connection:     Built in modem - ADSL
Current Status:    Fully Operational
DSL Connection Details
Broadband Link
DSL Line (Wire Pair):    Line 1 (inner pair)
Protocol:    G.DMT2+ Annex A
DSL Channel:    Fast
DSLAM:    Country: {0xB5} Vendor: {IFTN} Specific: {0xB971}
ATM PVC Info:    0/38
ATM Encapsulation:    Routed LLC
Is this the one ?
That's the one, David. Thanks. :)
David
DSLAM:    Country: {0xB5} Vendor: {IFTN} Specific: {0xB971} Thats a HUAWEI I believe
Thanks, Steve, my next job was to decipher the code. :)
There you are  ;D
ALCB = Alcatel (now ST Micro)
ANDV = Analog Devices
BDCM = Broadcom
GSPN = Globespan
IFTN = Infineon (Huawei)
STMI = ST Micro
TMMB = Thomson Multimedia Broadband
TSTC  = Texas Instruments
Digital Dadcu
Here's mine Rick.
Country: {0x0F} Vendor: {ALCB} Specific: {0x00}
Hi and welcome to the forum. :welc: :karma: Thanks, which router?
Digital Dadcu
Hi Rik thanks for the welcome.
The router is a 2-wire 2700 Dual SSID.
Software version 5.29. 117. 3.
Hardware version 2701-100589-005.
Thanks.  :thumb: That's two 2700s we know for sure about then. :)
The paged linked to above doesn't resolve for me, I'll try it again later.
Welcome to the forums Digital Dadcu  :welc: :karma:
It seems to be firmware dependent. :(
Ah I didn't realise that this was a local address although I should have as it did look familiar. I do have an updated firmware on standby in case things don't go to plan when I get switched tomorrow but I tend to operate on the basis that if it isn't broke...
rireed3
Mine is Netgear DG834g v5
G992.5, ADSL2+,  downstream sync 19787, upstream 1267
Suspect the MSAN is Huawei.
Does anyone know how to find a DSLAM/MSAN indication in Netgear v5?
Richard
