Is my router ok for the up-to 24mbit service u think?
Started by gyruss, Jun 06, 2009, 18:14:32
gyruss
My router is:
Linksys WAG54GS  and in the dsl modulation dropdown it does indeed display ADSL2 and ADSL2+.
But will it work? u think?
Jase
gyruss
Also very much contemplating switching my phone from bt over to idnet too.
Jase
It's hard to say as yet, Gyruss, we haven't had enough people move to WBC to build up the database of 'known good' routers. We should have had a better idea by now, but BT messed up all the migrations for this week, so the majority have yet to move.
As for the phone, I moved across in April, no problems, no down time, just better billing. :)
gyruss
I have two routers in the house, 1 which isn't in use is a Netgear DG834PN.  Thats kind of a backup router should the primary one fail :)
I don't want to upgrade and find both are not good for the service though as just buying yet another router may prove to be a pinch on the wallet right now.
Jase
The Netgear will be fine, it's the one router which has worked with all MSANs.
