Frequent loss of connection
Started by karser, Jun 15, 2009, 12:53:49
karser
Today I keep losing my connection every 30 seconds or less, 1st the adsl light goes out then the internet light goes, then a few seconds later it reconnects, is this an idnet problem or a bt problem? & anyone else having similiar trouble?
It's more likely to be a BT problem. Loss of sync is caused by an issue with your router, line or the BT equipment at the exchange.
Loss of sync is likely to be a local issue. Could you run something like RouterStats so we can see what is going on with your SNRM? :)
tomharrison
Agree with Sebby there (although it could still possibly be BT if it's just started happening), if possible are you able to post your line stats from your router?
Tom
IDNet Home Max
karser
thanks for the replies all, it appears to be behaving now, must have been bt doing some work.
Always possible right now, there's the 21CN and WBC work in addition to routine maintenance.
JohnH
Quote from: Rik on Jun 15, 2009, 15:47:37
Not at my exchange.  :sob:
I have WBC already, 21CN I think is next year. After that, I'll move. :)
karser
sigh I spoke too soon, just got home & its been out for half an hour, possibly longer  :mad:
Is it a case of lost sync or lost PPP?
Checked with support, they're not seeing 30 second drops, you did lose sync from ~4:55-18:03, but it looks from their end like the router re-started. Are you connected with a cable or wirelessly?
karser
Its been fine for a couple of hours since the outage, but now its playing up again, every minute or two the whole adsl is off for about 30 seconds then back on again, gonna have to ring idnet tomoroow myself if this persists, ty for taking the time to check with them.
Do you have a BT master socket with a removable lower half? If so, could you remove the plate carefully, and connect your router to the socket behind it?
karser
I'll try that shortly, dont know if this is any help but this is my stats normally:
   DSL Status:       Up
              DSL Modulation Mode:      GDMT
              DSL Path Mode:      FAST
              Downstream Rate:      8128 Kbps
              Upstream Rate:      448 Kbps
              Downstream Margin:      8 db
              Upstream Margin:      25 db
              Downstream Line Attenuation:      11
              Upstream Line Attenuation:      4
              Downstream Transmit Power:      0
              Upstream Transmit Power:      0
PVC Connection
              Encapsulation:      RFC 2364 PPPoA
              Multiplexing:      VC
              QoS:      UBR
              PCR Rate:      0
              SCR Rate:      0
              Autodetect:      Disable
              VPI:      0
              VCI:     38
              Enable:      Yes
              PVC Status:      Applied
And this is what they are like when it goes off:
   DSL Status:       Down
              DSL Modulation Mode:      NOT TRAINED
              DSL Path Mode:      FAST
              Downstream Rate:      0 Kbps
              Upstream Rate:      0 Kbps
              Downstream Margin:      2147483640 db
PVC Connection
              Multiplexing:      VC
              QoS:      UBR
              PCR Rate:      0
              SCR Rate:      0
              Autodetect:      Disable
              VPI:      0
              VCI:     38
              Enable:      Yes
              PVC Status:      Applied
I've also ssent a message to idnet through the "contact us" option, hopefully i will hear something tomorrow (if i can stay connected long enough to open my email ;) )
Your normal stats are absolutely fine. But when you lose sync, the noise margin (show above as a large number, actually indicating a negative figure) is fallen a substantial amount, which suggests bursts of noise. It's worth trying the test socket for a while when you can to see if this solves it. If it does, your issue is with internal wiring, which we can hopefully help you to solve.
Just a thought, but have you got any new electrical equipment which has been recently set up, like a DECT phone, or anything which could be affecting your internal wiring?
karser
nope changed absolutely nothing this end, & for the last 90 minutes it seems to be working normally again, hope it lasts this time.
The first thing IDNet are going to ask you to do is plug the router in to the test socket, if you have one. Then look at things like ring wires if you have multiple sockets and, finally, check with another router. Given your normal line stats, you've either got one huge noise source near you, or your router is tripping over.
