Routerstats 5.4a nd ST585v6
Started by D-Dan, Jun 18, 2009, 19:43:44
D-Dan
Has anyone got these two babies working together reliably. I've tried setting Routerstats to pick up what I want to monitor using the stats page and the alternatives, but it keeps losing noise margins?
I know that Routerstats Lite will work without a problem, but I want upstream as well as downstream stats for the next couple of weeks to see how my WBC is going on without having to login to the router via my browser (hovering over an icon is much easier).
By way of an example - see th following. And no - it's not wandering noise, the drops to 3 are Routerstats picking up a table formatting tag in the HTML instead of the NM.
[attachment deleted by admin]
Have I lost my way?
What about DMTtools I know it works with 585v6 and does give at least one margin graph?
D-Dan
Not with my firmware version - I'd need to downgrade firware which I'm loathe to do during a training period.
Have I lost my way?
I appreciate that Steve, I thought I'd mentioned it as I have got stats before with an incompatible firmware. I appreciate SNR manipiulation etc will not be available.
4Way
I never got it to work fully so went to the lite version. It was originally written for the Netgear routers and has been developed from there. Other routers don't give the same info as the Netgear hence the lite version. If you go on the forum on the website John usually replies promptly and has always been very helpful going as far to develop test versions to try on your router.
