PPP loss
Started by Bill, Jun 25, 2009, 09:40:21
My router log is showing a loss of PPP (sync stayed up) in the small hours this morning.
Can't be 100% sure when it started as it fell off the bottom of the router log, but from the system log it was around 1:05am. Came back at 5:05am
Anyone else?
Ross
No problem here.  :)
Nothing here, on GW5.
I should have said- I'm on DSL4.
 I'm on DSL4 as well, Bill   :)
Nothing here either (on gw6). That is the typical window for BT work though :)
Quote from: Lance on Jun 25, 2009, 13:24:37
I assumed it was deliberate, (1am to 5am takes some believing for a random fault!), and thought it was probably BT because IDNet usually tell you in advance if they're going to kick you off for a while  :P
Worth an ask though.
