Ping time majorly out
Started by MarkE, Jul 01, 2009, 15:36:56
MarkE
Hey just wondered if anyone else is suffereing from clunky net browsing again as well as ping times.
i am seeing well over 200ms currently to
multiplay.co.uk
as well as google being off the charts.However sync seems fine.
anyone else? I tried a router reboot and as well as powering it off for an hour,but alas its still the same. I am on gw5.
Colin Burns
C:\Documents and Settings\colin>ping multiplay.co.uk
Pinging multiplay.co.uk [85.236.96.22] with 32 bytes of data:
Reply from 85.236.96.22: bytes=32 time=85ms TTL=124
Reply from 85.236.96.22: bytes=32 time=104ms TTL=124
Reply from 85.236.96.22: bytes=32 time=121ms TTL=124
Reply from 85.236.96.22: bytes=32 time=116ms TTL=124
Ping statistics for 85.236.96.22:
i would say pings are a little wacked have you tried a router restart?
    Minimum = 85ms, Maximum = 121ms, Average = 106ms
Mohux_Jnr
I have got used to the daily reboots at 3.30pm EVERY day to bring my ping back down to normal but today has reached an all time low and has been on going since the upgrade months ago, I am afraid it may well be the final straw for me.
Pinging www.idnet.net [212.69.36.10] with 32 bytes of
Reply from 212.69.36.10: bytes=32 time=112ms TTL=59
Reply from 212.69.36.10: bytes=32 time=123ms TTL=59
Reply from 212.69.36.10: bytes=32 time=138ms TTL=59
Reply from 212.69.36.10: bytes=32 time=100ms TTL=59
    Minimum = 100ms, Maximum = 138ms, Average = 118ms
MarkE
Quote from: Colin Burns on Jul 01, 2009, 15:43:07
Yes i tried a restart as well as powering the router off for well over an hour Colin  :(
dujas
I'm on gw5 and have the same problem, router reboot makes no difference. Average ping to www.idnet.net is 147ms, pinging every 15 seconds for half an hour. I've emailed idnet, download speeds don't appear to be affected.
Pings very high here s well
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation.  All rights reserved.
C:\Users\>ping idnet.net
Reply from 212.69.36.10: bytes=32 time=200ms TTL=59
Reply from 212.69.36.10: bytes=32 time=215ms TTL=59
Reply from 212.69.36.10: bytes=32 time=208ms TTL=59
Reply from 212.69.36.10: bytes=32 time=163ms TTL=59
   Minimum = 163ms, Maximum = 215ms, Average = 196ms
C:\Users\>
I think this is one that only IDNet can look into.
Just spoke to idnet, they wanted me to drop my firewall to ping me, not something I particularly wanted to do really but its been reported.  :(
Lucky that's all they wanted you to drop! :P
Quote from: Sebby on Jul 01, 2009, 16:15:55
;D in this heat Sebby I wouldn't care
I'm on gw6 with no ping issues.
C:\Users\zappaDPJ>ping idnet.com
Reply from 212.69.36.10: bytes=32 time=24ms TTL=59
Reply from 212.69.36.10: bytes=32 time=23ms TTL=59
   Minimum = 23ms, Maximum = 24ms, Average = 23ms
C:\Users\zappaDPJ>
C:\Users\zappaDPJ>ping multiplay.co.uk
Reply from 85.236.96.22: bytes=32 time=24ms TTL=124
Reply from 85.236.96.22: bytes=32 time=23ms TTL=124
C:\Users\zappaDPJ>
netgem21
Yep, high pings and slow speeds here too on .dsl4   :(
Ping has started ...
PING www.idnet.com (212.69.36.10): 56 data bytes
64 bytes from 212.69.36.10: icmp_seq=0 ttl=59 time=156.042 ms
64 bytes from 212.69.36.10: icmp_seq=1 ttl=59 time=232.798 ms
64 bytes from 212.69.36.10: icmp_seq=2 ttl=59 time=255.875 ms
64 bytes from 212.69.36.10: icmp_seq=3 ttl=59 time=177.391 ms
64 bytes from 212.69.36.10: icmp_seq=4 ttl=59 time=170.535 ms
--- www.idnet.com ping statistics ---
5 packets transmitted, 5 packets received, 0% packet loss
round-trip min/avg/max/stddev = 156.042/198.528/255.875/38.726 ms
No good on .net either >100 I blame the tennis, similar issue to what we had with the Olympics? Hopefully improve when Murray finishes
Quote from: zappaDPJ on Jul 01, 2009, 16:17:49
C:\Users\zappaDPJ>
C:\Users\zappaDPJ>
Are you on ADSL: 2+ though? that would make a difference
Quote from: stevethegas on Jul 01, 2009, 16:20:34
I knew there was a reason I did not like Tennis  ;)
Quote from: Gary on Jul 01, 2009, 16:21:08
I am Gary.
Quote from: zappaDPJ on Jul 01, 2009, 16:23:41
I am Gary.
That makes a difference, last time ping issues happened the few on ADSL2+ did not have the problem.
Colin Burns
Quote from: Sebby on Jul 01, 2009, 16:10:48
they wernt so helpful when i rang and just said that all was well but i think not.
Anaxion
on GW5
Pinging www.bbc.net.uk [212.58.251.195] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 212.58.251.195:
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
Pinging www.l.google.com [209.85.227.99] with 32 bytes of data:
Reply from 209.85.227.99: bytes=32 time=141ms TTL=247
Reply from 209.85.227.99: bytes=32 time=181ms TTL=247
Reply from 209.85.227.99: bytes=32 time=166ms TTL=247
Reply from 209.85.227.99: bytes=32 time=179ms TTL=247
Ping statistics for 209.85.227.99:
    Minimum = 141ms, Maximum = 181ms, Average = 166ms
any comments?
Quote from: Colin Burns on Jul 01, 2009, 16:29:54
I know, not to impressed with the response I got I have to say.
Probably watching the tennis, I've emailed them with stats and directed them here.
C:\Users\>tracert idnet.net
Tracing route to idnet.net [212.69.36.10]
over a maximum of 30 hops:
  1     1 ms    <1 ms    <1 ms  192.168.0.1
  2   179 ms   179 ms   186 ms  telehouse-gw2-lo2.idnet.net [212.69.63.55]
  3   210 ms   204 ms   215 ms  telehouse-gw3-g0-1-400.idnet.net [212.69.63.243]
  4   167 ms   159 ms   164 ms  redbus-gw2-g0-1-331.idnet.net [212.69.63.5]
  5   166 ms   177 ms   183 ms  redbus-gw1-fa2-0-300.idnet.net [212.69.63.225]
  6   171 ms   177 ms   187 ms  www.idnet.net [212.69.36.10]
Trace complete.
C:\Users\>
Colin Burns
Quote from: Gary on Jul 01, 2009, 16:36:13
i think the tech i got might have worked for Tiscali or Talk Talk and left it off his CV
and still has a copy of the how to lie to customers manual
Quote from: Gary on Jul 01, 2009, 16:26:21
So those of you that are having problems are on the 8 Mb service? It's something I need to to consider as I'm currently looking at switching back  :-\
Danni
Yup- no ADSL2+ from BT here yet :(
Adding my pings here to keep that part in one thread :)
danni@Matilda:~$ ping idnet.net -c5
PING idnet.net (212.69.36.10) 56(84) bytes of data.
64 bytes from www.idnet.net (212.69.36.10): icmp_seq=1 ttl=59 time=161 ms
64 bytes from www.idnet.net (212.69.36.10): icmp_seq=2 ttl=59 time=183 ms
64 bytes from www.idnet.net (212.69.36.10): icmp_seq=3 ttl=59 time=194 ms
64 bytes from www.idnet.net (212.69.36.10): icmp_seq=4 ttl=59 time=164 ms
64 bytes from www.idnet.net (212.69.36.10): icmp_seq=5 ttl=59 time=174 ms
--- idnet.net ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4001ms
rtt min/avg/max/mdev = 161.148/175.722/194.745/12.471 ms
