Supreme commander...for those with brains!
Started by AvengerUK, Feb 21, 2007, 15:06:41
AvengerUK
Finally, a new release of the RTS genre!
Got it yesterday, took ages to install, as 10GB Does! - once installed, i ran it, and felt my jaw drop! I havent played a game as good as this since "the good old days" (such as Age of Empires!), and, the only problem with it is that it seems to be designed for "next gen pcs" - by that i mean dual core is really needed.
has anyone else had the pleasure of trying this game? if so, what did you think of it!?
siege2
Played the Beta online no probs
whilst with the newly purchased game everything bar 1 , the multilplayer client GPGNET, ie the .exe does
not get installed when i click on the multiplayer icon I get this cannot find GPGnet.multiplayer.client.exe
BYW
http://forums.gaspowered.com/viewtopic.php?t=872
Home SuperMax "BT IPStream Max Premium"
_____________Downstream____Upstream
Data rate...........8128.....................832
Noise margin.....8.1  ......................12.0
Output power....7.8.......................12.5
Attenuation........4.0.......................2.0
AvengerUK
It installed fine with me :/ you just have to make sure you ask for it to be installed when you start the installation.
siege2
did that lots off people are having the same problem
AvengerUK
o, i think theres a patch coming very soon for it, so that should hopefully fix GPG (even those of us who have it installed...its still a bit iffy!)
mrapoc
#5
Tried the demo...hated it so bad
You have to zoom all the way in to get any detail, then you cant do anything...
Command and Conquer Tiberian Wars out soon  :P Loved every single C & C game!
I argue Company of heroes is the best RTS out atm :D Theres a DX10 patch out soon  :-* OOOOOh yes
Source
neocr0n
Quote from: mrapoc on Feb 23, 2007, 16:59:18
Hah your not alone there, CoH is awesome.  As good as the game is I hope they release a modern combat one where they have more freedom to work & be creative.
Play Counter-Strike 1.6 online 6 years and counting. :(
siege2
Hi
Last night played Command and Conquer 3 it has skirmish mode 1st level to play etc very good game game
gonner be buying that and multiplayer it when it comes out March
siege2
AvengerUK
"You have to zoom all the way in to get any detail, then you cant do anything..."
The whole point is to zoom in and out. Thats what make it different, and the best RTS ive played to date!
mrapoc
