Snow Leopard coming soon
Started by Steve, Aug 17, 2009, 22:01:26
I like the way you can place for instance the applications folder on the right side of the dock and display them as a stack a bit like Windows I suppose but unlike Windows if I don't like it I can get rid of it
[attachment deleted by admin]
There is a very comprehensive review of Snow Leopard here well worth a read.
PS my pre-ordered copy from Apple has still not arrived but that's probably down to the Royal Mail chaos and the use of 2nd class post :mad:
Quote from: Sebby on Sep 01, 2009, 19:18:33
Same here. I'm hoping Widemail is going to be updated soon.
Letterbox which is similar to the wide mail plug in may be out for SL on September 8th
Quote from: stevethegas on Sep 05, 2009, 23:05:58
There's a 64 bit beta out http://harnly.net/2009/software/letterbox/letterbox-beta-4-for-snow-leopard/#more-227
PS I am trying it out I'll report any issues ;D
Funny that - I just installed it before coming onto IDNetters. It seems to be working fine. :)
