Question about IDNet Phone
Started by Rapier Racer, Aug 20, 2009, 17:18:33
Rapier Racer
Thinking about transferring the phone line over to IDNet. This is mainly because I want the line only for my broadband and so I'm looking to just pay for line rental. My question, is it possible to have a bar put on outgoing calls? I don't live alone and don't want someone connecting a phone to the extension boxes and making calls.
I don't know, a quick call to support and they will tell you
Call barring should be available, but it's an additional charge usually.
glue the phone connection part shut ?  :P
JohnH
Quote from: Rapier Racer on Aug 20, 2009, 17:18:33
If you are only going to use the line for broadband, you could also disconnect the extensions, which could improve your broadband performance anyway.  :)
Rapier Racer
