Loss of service reports
Started by rireed3, Sep 23, 2009, 16:37:06
The burden of proof eh Zap.
Exactly that. If I were a cynic I'd say the BT speed test was written to return a good result or the best result of a set of average results or no result at all from a set of bad results.
You may think that but I couldn't possibly comment*
*just in case any BT lawyers are watching
Yes it is, Zap. My guess is that it's BT exchange work though, there's a whole raft of it going on this month.
Quote from: zappaDPJ on Nov 02, 2010, 09:25:04That said, the preliminary test did show speeds well below the acceptable range.
Is this worth pursuing?
IIRC, the BT speedtest says that the results are stored and can be retrieved at the request of your ISP... so yes, it probably is.
Although yesterday's test failed on the final test, hopefully it'll have recorded what prompted it.
Quote from: zappaDPJ on Nov 02, 2010, 11:50:56
It probably has... I've found that if I abort a test after the download but before the upload completes it still won't let me run another test for an hour, so it's remembering something!
What it had for breakfast probably, Bill. ;)
Cornflakes probably... fibre is good for it :P
:grn:
More seriously, it seems to me that it records a successful test if it tells you your profile.
I found it had to complete at least the download test... but come to think of it, that was before the version for VDSL came in so it may have changed.
I got a profile and then it just died on me the other day, Bill. A retry got the 'go away' message.
Old version just did a download test, new one does download and upload irrespective of the bearer it would appear.
Is that bad news, Mitch? ;)
I've lost both my connections again this morning, anyone else?
Cheers. I've managed to get back on ADSL by rebooting the router but it won't work for FTTC. I have sync with the exchange but no DNS.
cs
MY FTTC connection is fine
Rgs
Chris
Chris
Thanks, it's just me then :'(
BT faults
BT30825   06/11/2010  09:52
01595   01806   01857
01950   01957
BT31297   06/11/2010  09:35
01569
BT31289   06/11/2010 09:32
01347
Thanks Steve, I'm not on the list.
I did find this on Zen...
Clear    PW144150    06/11/2010 02:00    06/11/2010 03:00
Needless to say there was no outage during that time ::)
