Loss of service reports
Started by rireed3, Sep 23, 2009, 16:37:06
This is from the Lerwick outage
"Service has been restored by completing a
Card Change
This issue may have been due to
a Denial of Service (DOS) Attack
an Equipment Failure
BT regrets any inconvenience this may have caused."
DoS  :eek4:
Quote from: Steve on Nov 06, 2010, 20:15:44Service has been restored by completing a Card Change
In other words, having taken a card out, they finally got around to putting a new one in :P
Huh? Can a DOS break a card? Overheating it? What? I'd guess most failures are hardware if it needs swapping out. You cannot really blame software, even if it goes astray or is malicious.
Unless a firmware update goes awry and bricks the card.
To me, it's worrying that the equipment is so vulnerable to a DoS attack. And why Lerwick for heaven's sake? A test run?
Would the Lerwick exchange connect back to a single card in the Edinburgh node? If so, then the attack, if there was one, may have targeted that card in the node, possibly chosen at random.
It's quite likely, isn't it.
As I've said, when I was being upgraded to Max a line card in the exchange failed and took BT a week to replace it.
10 days for me, Mitch. BT doesn't do urgency. :(
I had a new line laid in my garden, within 7 days.
It took 2 or 3 years of a noisy degrading line. for them to decide to do it though.
If they don't get you one way... ;D
gazzthompson
Service down. Norfolk, watton . 3rd time in recent times .
I can't see anything listed in the service outages, so you may well be going through the birthing pains of 21CN on the voice side.
dlorde
My connection just went down - I restarted the modem and it shows an internet connection and the log shows PPP connection was OK...  ???
Anyone else having problems?
dlorde
Hmm... OK, thanks Glenn, looks like it's just me  :(
dlorde
OK, panic over - connection is back up again now.  :)
mrapoc
Ive been down all day router been off to try fix it. Not cool any ideas?
How long did you leave the router off for? Do it for 30mins to ensure a stale session has time to clear. What does the router show?
mrapoc
All day. Same old no external ip
Have a word  with support, Sam, see what they have to say.
mrapoc
Support couldnt see my router, aka a stale session, so even leaving it off for a day didnt help there, they had to reset it their end
All sorted now
 :thumb:
Suddenly, the cures we've relied on for years are ceasing to work, Sam. BT are doing some odd things.
