Unexpected speedtest result
Started by D-Dan, Oct 15, 2009, 20:01:16
D-Dan
I arrived home and noticed my SNR had increased from it's usual 2.5 (I've already documented elsewhere that this is stable), and fearing the worst, checked sync expecting to see a drop. As it happens, sync has increased with SNR (very strange) but that's not what's baffling; since the change won't affect my bRAS it matters not a jot.
Nevertheless, just to be sure nothing was amiss, I did a test at BT. Here are the results:
Download speedachieved during the test was - 6720 Kbps
Additional Information:
Your DSL Connection Rate :8538 Kbps(DOWN-STREAM), 979 Kbps(UP-STREAM)
The curiosity is my upstream sync. I thought it maxed out lower than this. Have there been some changes?
Have I lost my way?
rireed3
I think you are on ADSL2+, which can go above 1200 Kbps upstream.
Richard
Very strange, Steve, but then ADSL2+ is a strange beast. ;D
D-Dan
Quote from: rireed3 on Oct 15, 2009, 20:38:55
Richard
I am indeed, but I thought we were limited to 896Kbs here.
Have I lost my way?
I'm pretty sure Richard is right. Certainly the information on the packages on the Idnet website suggests a much higher sync.
I wouldn't complain, Steve!   :D
D-Dan
 :zip: Who said I was complaining :D
Have I lost my way?
Oh, sorry.  Whenever anyone mentions speed on here, I automatically think it's a complaint!  :)x  ;)
