Vista SP2
Started by Noreen, Dec 04, 2009, 11:43:45
Noreen
I've not updated my Vista Ultimate SP1 to SP2 because I understood that it's basically just all the later Security Updates and I've installed them anyway.  Is there any reason why I should install it, I don't appear to have had any problems?
Completeness? I should imagine that it would only install the bits it needs to. Sooner or later, MS will drop support for SP1 as they did with XP.
I thought it includes performance enhancements.
It foxed some issues it was not all previous updates and when I had Vista it was more stable after, its best to stay up to date on service packs.
Colin Burns
i took the plunge with the install of suicde pack 2 on my vista laptop.  not noticed anyreal difference in performance or general uselessness that i tag with vista
:)x
In fairness to Vista, I did find that SP2 made a noticeable improvement, but obviously it's still not great.
Noreen
Does installing SP2 involve a lot of bother and would it mean reinstalling all the Security Updates issued since it came out?
To judge by XP SP2/3, no, it looks at what you've already installed and then fills in the gaps, quite painless - though do take an Acronis image first.
Colin Burns
Quote from: Sebby on Dec 05, 2009, 16:35:12
:)x
it could just be the lack of use my laptop has been getting
Quote from: Noreen on Dec 05, 2009, 17:19:38
the install was painless for me
