Coming back Idnet - What can I expect
Started by johnhol, Dec 07, 2009, 13:41:08
johnhol
Well, had a fiddle with the phone socket and seems stable though location means it can be knocked  :mad:
Stats are:
--- DSL Information ---
DSL Driver Version:  AnnexA version - A2pB022g.d20e
DSL VPI/VCI:         0/38
DSL Status:          ShowtimeRetrain Reason:   8000
DSL Mode:            ADSL2+
DSL Channel:         FAST
DSL Upstream Rate:   1180 Kbps
DSL Downstream Rate: 16634 Kbps
                      Down         up
DSL Noise Margin:     2.9 dB       6.7 dB
DSL Attenuation:     27.5 dB      12.9 dB
DSL Transmit Power:   0.0 dBm     12.6 dBm
My IP Profile is still set to 12mb so hoping this gets bumped up to the next level - though not sure what this is - some calculator said maximum sync could be just over 18mb and max achievable download of 16mb???
That sync speed will get you a 14M profile, John. To get 16M you need to sync between 18176 and 19295. TBH, I can't see that happening with a noise margin of 2.9db, if anything I'd expect your line speed to drop 500-1000k.
