How do I change username and password in this router ?
Started by David, Dec 13, 2009, 12:06:23
David
Its a David "Special"folks..I cant find the set up thread but a little while ago I changed my router to my reinstate my 2700 because I wanted the wireless function..but no matter how I tried the user name would not change...what did I do wrong.I have had to revert back to my other router which is wireless but the set up is mental..or I am.
I am watching a netgear on that famous auction site as they are so easy to set up and I do need to get the other machines in the house on-line without using miles of cables
The part you want to read is;
QuoteNote when this configuration data is complete do not click the Submit Settings button at the bottom of the page.
At first this is what I did and it does not work.
Instead in your browser's address bar type: javascript:document.pagepost.submit() and press enter.
This saves the correct details but bypasses the validation present in the BT firmware.
David
That is where I went wrong Glenn....... :blush: I will try again later  :thumb: :thanks3:
I wont bid on The Netgear now.. :thumb:
David
I have 2 here at present....one is not wireless the other one is but when it comes to putting in the binary numbers I just glaze over and there is 10 or more of them..so it maight be a good idea after all  ;D
David
More room needed in the bottom of the wardrobe  ;)
David
David
Not for the cables,speakers mice keyboards filters modems kettle leads and god knows what else all of which for some reason I am loathed to throw out............................I need help  ;D
David
Now is it How Clean is Your House........or Location Location Location I know which one appeals more  ;)
