Windows 7 question
Started by klipp, Dec 22, 2009, 17:21:49
klipp
Hope I've posted this in the correct section.
I have a laptop with Vista Home Premium on which I want to upgrade to Windows 7.
If i get the "upgrade" edition of Windows 7, will I need my Vista's serial number to install?  I can't seem to find it!!
Thankies.
You have now. ;)
I think you would probably need the Vista CD if you're doing a clean install. If you install over, you probably wouldn't need anything.
You can upgrade over Vista quite easily but be prepared for a 1 to 2 hour process.
D-Dan
or 4 in my case :(
Also, run the Windows upgrade advisor and uninstall anything it finds. In addition, if you use Comodo firewall, uninstall that first too (If I wasn't already bald, the Comodo issue would have had me pulling my hair out).
You can re-install after the upgrade.
Have I lost my way?
