save log in email details?
Started by nuevo, Jan 14, 2010, 09:46:31
nuevo
hi there
Can someone please tell mw how to get my pc to save my (idnet) email log in and passward details.  The save/remember option does not appear and I cannot find any option in the idnet email site.
I use Windows XP.
Hi Nuevo
Do you mean for webmail? In which case you can't do it. If not webmail, could you tell me exactly where the problem is?
nuevo
It's just my personal email with idnet.
nuevo
I saved the IDNet Webmail - Welcome to IDNet Webmail page with the username and password login box.
As I said, you can't save the webmail login, for security reasons. You'd be better off using an email client if you can.
nuevo
Apologies for the (daft) question but by email client do you mean Thunderbird (for Firefox) or Outlook (for IE)?
Thanks again :thumb:
Yes, if you download them what do you use?
Yes, or Windows Live Mail if you're running Vista or Windows 7. The email clients are not tied to the browser, though, I use Firefox and Outlook, for example.
nuevo
I use mainly Firefox and will set up either Outlook or Thunderbird.
Thanks for the help. :thumb:
What browser are you using Nuevo?  In Firefox or SeaMonkey, you can store your webmail log in, in the Password Manager.  If it won't ask if you want it to remember it, it may already be there (check Password Manager), it may be in the Passwords Never Saved list, or Password Manager may not be enabled.  I have 5 IDNet email accounts, all of which are accessible via webmail, and all of which are remembered by Firefox / SeaMonkey.
Odd that, Simon, I've never been able to get it to store passwords, and have assumed it's a security measure. It's not already there and it's not in the never saved list...
I can't answer how, Rik, but I have the whole list of logins offered when I visit webmail.
Curious, I do for my portal logins, but not the new webmail, only the old.
There's something different about the webmail, Rik, normally FF asks on other sites if I want to save the password but it never does on the Idnet webmail login.
That's my experience, Ray. It's like a bank login.
I'll check again later, but I'm sure mine does.
JB
This article may be of interest. The edit worked for me last time I tried it.
http://www.mydigitallife.info/2008/08/16/fix-firefox-does-not-save-store-or-remember-password-on-some-sites-permanently-for-always-auto-complete/
I think you need to re-do the mod each time Firefox is upgraded.
Edit: It's line 812 in my Firefox 3.5.7 on WinXP.
JB
Quote from: Simon on Jan 14, 2010, 16:50:11
What version are you running and have you got any external password manager running, Simon. Brian and I have just tested with 5 browsers and none of them offer to save the login details. This would make sense, as people might access webmail from a 'net cafe etc.
Quote from: 6jb on Jan 14, 2010, 16:57:16
Thanks, JB, that almost certainly explains what is happening, if not why it works for Simon. :) :thumb:
I haven't done any mods, and don't forget, my primary browser is Sea Monkey.  Have you tried it in that?
I'm struggling to think of the five you did test, then!
