ping results
Started by Happy Surfer, Feb 07, 2010, 19:03:20
Happy Surfer
hey peeps done a ping test from bbc and got back 38ms average with lowest being 36ms,just wondering how this fares with other peoples results and what an average result is from bbc.
Thats probably not too bad although mines lower at 20-25ms, its dependent on many factors such as exchange congestion,whether you have priority at the exchange,how far you are away from the server,whether your connection is interleaved or not and whether your adslmax or WBC.
RA-1972
Pinging bbc.co.uk [] with 32 bytes of data:
Reply from 212.58.224.138: bytes=32 time=16ms TTL=122
Reply from 212.58.224.138: bytes=32 time=15ms TTL=122
Ping statistics for :
    Minimum = 15ms, Maximum = 16ms, Average = 15ms
Happy Surfer
#3
im on adsl max my profile is 7150 and im always averaging 6.6meg on bt speedtest i dont know if i am interleaved or not and exchange is just down the road bout 150-200metres
[attachment deleted by admin]
HS, I'm averaging around 28ms to the beeb.
Happy Surfer
not that im having problems with ping when gaming but is there adjustments that idnet are able to make to improve or prioritise ping?
im just asking out of curiosity just so i know in the future wether it is possible should the situation arise :)
Home Super Pro is traffic prioritised at the exchange, along with 3 of the 4 business packages.
Happy Surfer
ok thanks glenn, have idnet upped the gb allowance on all the packages? if they did they sure kept that quiet, idnet being modest as always
It was announced first on the forums - here - and they also sent out an email to customers.  ;)
Quote from: Happy Surfer on Feb 07, 2010, 21:05:43
You may or may not have an interleaved connection, interleave is BT's method of reducing the amount of errors that arrive at your router and thus aids throughput if the error count is high. Unfortunately an interleaved connection tends to have higher pings times due to the latency induced by interleaving.To find out look here for more stats http://www.kitz.co.uk/adsl/frogstats.php, the stats may show FEC or forward error correction(interleave) or ask support.
