Cannot get any lower
Started by old Bill, Mar 08, 2007, 08:40:46
old Bill
Just ran a BT speedtest. At least I know the only way is up. :)
    DSL connection rate: 832 kbps(UP-STREAM)  4832 kbps(DOWN-STREAM)
    Actual IP throughput achieved during the test was - 0 kbps
Could you access the net at the time, Bill? I just wonder whether you had a stale session problem there?
Did you run a second speed test after this one? It may be that an error occured.
old Bill
Back to normal. It looks like my system has a problem with its wireless card some ware. I ran a speedtest a while later and it was fine. Just have to sort the new system out now.
