I'm moving
Started by psp83, Mar 15, 2010, 17:22:10
You don't Baz, it's a fee payable for an 'as is' service. BT would simply argue that the line is delivering a broadband service. OTOH, if you use the bandwidth, you'll cover the fee in a couple of months or so.
well im out of the training period now and am just monitoring things.Had a bit of a slow few days early on but did some testing suggested by support,in the test socket with filter in etc and also did  router reboot at the same time.Things are looking good so far with a BT test showing this
Download speedachieved during the test was - 8173 Kbps
For your connection, the acceptable range of speedsis 600-7150 Kbps.
Additional Information:
Your DSL Connection Rate :9821 Kbps(DOWN-STREAM), 888 Kbps(UP-STREAM)
IP Profile for your line is - 8000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 23.7:18.89:57.41 (SBE:NBE:PBE)
and speedtest.net
looking ok so far  :thumb:
Another speed higher than profile result, Baz, BT have done something weird to the tester. Look good otherwise, though.
thats what I was thinking Rik but I dont know enough about it to say so  :)   its not always that way though,has been lower most of the time
The tester has been showing these odd results recently. Whether it's screwy or the profile mechanism is broken, I really don't know.
what is going on
got this from BT tester,second similar one today.
Download speed achieved during the test was - 8628 Kbps
For your connection, the acceptable range of speeds is 1000-99999 Kbps.
Your DSL Connection Rate :10685 Kbps(DOWN-STREAM), 888 Kbps(UP-STREAM)
IP Profile for your line is - 9000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 13.75:21.18:65.08 (SBE:NBE:PBE)
Im not complaining but if you look back a few posts you'll see what I have been getting lately,just after the training period.Also did a speedtest.net test and got 3.45 download speed.theres no chance ive gone back into another training period is there as this is how it started when I initially switched.
Baz your connection is always being trained at the exchange the only difference is that during the initial training period you cannot report a broadband fault. Low throughput for a given profile is usually due to congestion somewhere along the path or a high error count
Today my speed is also down, normally get around 5.3mb today I'm lucky to get over 2mb.
Pings are normal though.
its really slow this afternoon.hope this is not the norm or i'll be moving back I think
As you can see by a BT speed test, My speed is normal.
Download speedachieved during the test was - 5139 Kbps
Your DSL Connection Rate :6352 Kbps(DOWN-STREAM), 1016 Kbps(UP-STREAM)
IP Profile for your line is - 5500 Kbps
But speed test sites show different :
maybe just one of those days then.will give it a while and see if it picks up or we get reports of any bother
Quote from: Baz on Apr 26, 2010, 15:51:42
As Steve says, line management is constant, Baz, but you're getting correct throughput for your profile, which is correct for the sync speed, iow, as far as BT are concerned you line is behaving just as it should.
I think the speedtest sites and/or the internet in general is performing poorly in relation to the BT speedtest.
Back to normal now.
I just do not understand the BT tester.since switching  to ADSL2+ it settled down after the training period and I was getting good speeds.Was getting connection speed down of 10685 and up of 888,a 9000 profile and actual speed achieved of around 8750 up to 9000+ sometimes.great  :thumb:
Had a little dropped connection this week and when it got running again after a reboot got this 12598 down 888 up 9462 actual and 9000 profile.have just looked today and got this
Download speed achieved during the test was - 5980 Kbps
Your DSL Connection Rate :12598 Kbps(DOWN-STREAM), 888 Kbps(UP-STREAM)
IP Profile for your line is - 11000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 10.77:29.21:60.02 (SBE:NBE:PBE)
:dunno: :dunno: :)
Exchange congestion from the look of it, Baz.
