Incredibly slow internet tonight
Started by klipp, Mar 16, 2010, 22:39:54
I've not noticed anything amiss tonight on my connection.
:welc: Maiku :karma:
[EDIT] However, I can't ping that IP either.
Microsoft Windows [Version 6.1.7600]
Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
C:\Users\zappaDPJ>traceroute irc.rizon.no
'traceroute' is not recognized as an internal or external command,
operable program or batch file.
C:\Users\zappaDPJ>tracert irc.rizon.no
Tracing route to irc.rizon.no [85.196.81.211]
over a maximum of 30 hops:
  2    16 ms    15 ms    15 ms  telehouse-gw2-lo1.idnet.net [212.69.63.51]
  3    15 ms    16 ms    15 ms  telehouse-gw3-g0-1-400.idnet.net [212.69.63.243]
  4     *        *        *     Request timed out.
Quote from: talos on Mar 17, 2010, 20:18:20
Well I assumed you would be there too, even if only to take notes :dunno: :D
So you will be needing those blue pills then  :D
Maiku
Thanks for the warm welcome :)
Seems like the problem fixed itself as I can get to everything again now.
Pings a bit high but dosnt appear to be affecting anything.
root@miyuki:/# traceroute irc.rizon.no
traceroute to irc.rizon.no (85.196.81.211), 30 hops max, 40 byte packets
telehouse-gw2-lo1.idnet.net (212.69.63.51)  92.198 ms  92.330 ms  92.191 ms
telehouse-gw3-g0-1-400.idnet.net (212.69.63.243)  92.712 ms  93.301 ms  93.896 ms
gi8-27.mpd01.lon02.atlas.cogentco.com (149.6.148.205)  94.583 ms  94.831 ms  95.188 ms
te1-2.ccr02.lon02.atlas.cogentco.com (130.117.50.117)  95.447 ms  95.348 ms  96.371 ms
te0-0-0-1.mpd22.jfk02.atlas.cogentco.com (154.54.30.17)  167.920 ms  168.263 ms te9-2.mpd02.lon01.atlas.cogentco.com (130.117.48.153)  170.587 ms
te4-3.ccr01.jfk07.atlas.cogentco.com (154.54.2.62)  173.677 ms te0-0-0-1.mpd21.jfk02.atlas.cogentco.com (154.54.30.129)  121.906 ms  107.117 ms
gblx.jfk07.atlas.cogentco.com (154.54.11.62)  112.920 ms  109.766 ms gblx.jfk07.atlas.cogentco.com (154.54.14.70)  109.789 ms
NOPAS.ge-0-3-0.109.ar1.OSL1.gblx.net (64.211.166.110)  243.192 ms  242.315 ms  242.441 ms
c85-196-92-154.static.sdsl.no (85.196.92.154)  247.246 ms  247.504 ms  246.285 ms
10  alfa-1.fiber.dg.no (213.158.248.6)  244.915 ms  212.615 ms  212.492 ms
11  underworld.rizon.no (85.196.81.211)  214.586 ms  215.843 ms  215.434 ms
root@miyuki:/#
False alarm i guess. Thanks for your help tho :)
Sept 22nd 2011, IDNet 8mb ADSL max. Draytek vigor 100 & a Soekris net4801.
I can't access it either, drop support an email.
mankatron2009
Quote from: Maiku on Mar 17, 2010, 23:58:44
Anyone else having some problems tonight?  For the last 20 minutes I cant get to Norway...  :eyebrow:
You might want to try norwegian.no.
Maiku
Quote from: mankatron2009 on Mar 18, 2010, 14:21:28
LOL
I even went to that url thinking "oh a site in norway to try" which yes it is but also being the airline was very funny :thumb:
I've had a couple other instances since my first post where a site isnt reachable then it works about 20 mins later. I tested it via daveproxy which also couldn't get to it, I'm wondering if the LINX is quite 100% back to normal yet.
I havn't contacted support with it as I've already been bugging Simon with other questions recently lol.
Jimbo
Hi all
I've been having problems for the past few days, last night and tonight it's been on and off.  I'm sync'd but last night, I couldn't get authorised.  PPP?  And tonight, it's connected but I'm getting packet loss on pings and web pages are loading / not loading.  Changed my DNS entries just in case, but no joy.
Sorry for skim reading the topic, but is there / has there, been a hardware fault?
Not having much luck here.   :dunno:
Thanks for any help.  It's driving me loopy!
There was a blip affecting the hostlink, and there's been an issue with LINX causing routing failures, but both are resolved. You really need to talk to support if it's a PPP issue, as they will be able to see your line and what's happening from their end. I assume you haven't changed anything in your setup recently?
Jimbo
Quote from: Rik on Mar 19, 2010, 19:00:54
Hi Rik
Cheers for that.  Again, sorry for not reading the whole thread.  :whistle:
No, nothing's changed mate.  I've recently been moved to ADSL2+ and I was about half way through the "training period".  But it's been rock solid until this all started.  Only settings I've changed was the DNS as when I saw Webpages were not loading I thought it maybe that.  I've also had the Router turned off just in case.
I'll see how it fairs for the rest of the weekend and if it's no better I'll contact support in the morning.
Thanks again.
Where did you change DNS, Jimbo, router or Windows?
Jimbo
Quote from: Rik on Mar 19, 2010, 19:07:51
On my Router. :)  Then I did a /flushdns in Windows and tried the Internet again.  I have the NIC set to 'Obtain DNS Automatically'.
Is that correct?
Thanks.
I'd always recommend changing the DNS within Windows itself, Jimbo. That way, you don't force a re-sync and a potential PPP issue. Try changing the router back to picking up the DNS automatically and see if that helps.
Jimbo
Quote from: Rik on Mar 19, 2010, 19:13:46
Ahhh OK thanks mate.  :thumb:
Ham
still experiencing some browsing problems here atm some sites are slow ie: ebay,autotrader ect some seems to be fine pings are fine :dunno:
Quote from: Ham on Mar 20, 2010, 00:43:33
Things seem back to normal here, could it be your exchange? Or just site traffic being very high?
Edit: Just checked those sites and no issues here
No problems here, Ham. If the problem persists today, can you run a BT speed test and post the results please.
Ham
Quote from: Rik on Mar 20, 2010, 10:40:03
seems ok today m8 will run a test if it gets bad again  :thumb:
adamr8965
it's slow 2nite, im struggling to load some pages on getting half my usual 7meg download speed. any ideas?
If I had to guess I'd say exchange congestion which should dissappear  as the evening wears on. However if it doesn't can you do BT speedtest? There's also been a LINX issue this week and I think the odd web site is still not resolving correctly. Personally I've had no issues lately and speeds are fine tonight
