Contention on Home Max
Started by Tanzanite, Mar 17, 2007, 17:48:25
Tanzanite
Hi All,
I am considering signing up with ID Net and wanted to know what the contention is for Home Max. It lists it as n/a. Does this mean it's 1:1 ?
Thanks.
Adam
It's certainly not 1:1; I believe it is n/a as BT no longer specify the contention rate on the ADSL Max products.
Adam
Tanzanite
So does that mean I could be sharing it with 50 others?
You could be sharing it with as many people there are connected to your exchange, however, BT do have guidelines which they follow to ensure that your internet does not become too slow. It is not a set contention anymore. Hope this helps!
Tanzanite
Ok, thanks very much for your help  ;D
No problem :)
If you want to know anything else, please feel to ask!
CaptainSlow
I'm surprised they don't rate it as "up to" 100:1 or something snazzy like that!  :D
It's not like BT to miss a trick that wide! ;D
The problem is, they couldn't agree on how many zeros to quote. :)
wrtpeeps
contention changed fior max
Don't eat yellow snow.
