WHS Vail beta
Started by Glenn, Apr 27, 2010, 07:30:35
The new WHS vail beta is now available via Windows connect, it's a near 4Gb download in total.
Thanks, Glenn,must download and have a play with that. :thumb:
I'll be downloading at work later today  ;D
I am leaving that alone as my unit is headless
I read that as VHS for a moment, and thought I was in a time warp. ;D
Quote from: Rik on Apr 27, 2010, 09:10:14
Don't worry,Rik, I'm in a time warp most of the time! ;D
Now thats another corny song  :music: Let's Do The Time Warp Again :music:
Downloaded and successfully installed, only have it connected to my Laptop for backups though as you need to remove the old connector software for WHS 1.
WHS Vail is very different and now has the look and feel of Windows 7 and integrates into the Homegroup if you are running W7, the installation is much more reliable and slick than the prevoius version.
On the client computer the old Homeserver Console has gone and has been replaced by a Dashboard that can be run full screen or any size you want like a normal window, looks a potentially good OS when it is finished.
Does it wipe the data drive? I may try it on a different PC to my server anyway.
Quote from: Glenn on Apr 27, 2010, 16:00:17
Yes it does, Glenn, and it needs at least a 160GB drive to install on, I've put it on one of my old XP machines that I no longer use.
I've just built a new PC, so apart from a case & HDU, I could use the old parts.
Looks like this release needs to be used with caution as data loss is a possibility.
Got it installed and running on my test machine now, seems to have been a lot of changes from the previous version especially to the Dashboard.
Do we know when it's due for non beta release?
I read November time. That was going by the beta release date, and the time MS took over the current versions beta period.
Last I heard mentioned was Q1 2011.
The current version is working happily in the background at the moment, so I'm in no rush.
