OK, I'm really confused now
Started by Rik, Apr 28, 2010, 15:07:48
It would be handy if they could just press a button, or move a jumper, to restore your default settings
They can, Glenn, his name is Reg. ;D
 ;D
I did mean you personally though.
 ;D
I can do it, I just need to believe I can. :)
I appreciate Rik that these matters are best left until an appropriate moment and tonight and tomorrow are not the time to be left with a duff machine
Some mobos when set on auto Rik may not supply the right settings, I had to adjust mine on my last windows machines, also when using just two sticks of Ram it went into slot 1 and slot 3 so there was a gap between them, this was to run in dual channel mode, modern Ram of good quality is capable of being over clocked and not having issues, if the timings are not as they should be I would be inclined to follow the advice and change them and increase the voltage. I would check with those ram slots though thats very odd. Dual channel is normally 1-3 2-4 in that order with matched pairs.
The slots are definitely correct, Gary, the yellow one from each bank, which is A1/B1 according to the manual.
