profile
Started by Baz, May 07, 2010, 14:31:29
what causes your profile to drop and do you need to do any thing when it does
Eating too much fatty foods and lack of excercise.  Says it all really. ;D
Noise on the line generally Baz. If it was just a quick burst, the the profile should recover on it's own accord.
If you stay up for 14 days solid, say 15 for safety, then reboot the router will your noise margin if its been put up should drop and you may gain a bit more speed, well it used to before WBC not sure if that still applies now, hopefully someone can say
Profiles seem to be recovering quicker on 21CN, we've big changes in 4-5 days.
A profile should recover in anything from a few hours to five days, Baz. Gary is thinking of changes to noise margi, which take 14 days+ per 3db step.
Quote from: Rik on May 07, 2010, 15:43:17
Im not sure I was actually thinking at all at that moment, Rik.  :slap:
thanks all apart from Alf  :nana: :nana:   ;)
Quote from: cavillas on May 07, 2010, 14:37:46
did a BT test at 2.30 and profile had dropped from 9000 to 6000 everything else was ok.just done another and its back up again  :dunno:
That's about par for the course, Baz.
The joys of BT  ::)
