somethings gone terribly wrong
Started by coreservers, May 27, 2010, 20:05:30
coreservers
absolutely crawling tonight. so looked at router stats
Connection Speed 285 kbps 1040 kbps
Line Attenuation 35 db 9.5 db
Noise Margin 31 db 5 db
:eek4:
and treid to run bt test twice
Download speedachieved during the test was - 164 Kbps
For your connection, the acceptable range of speedsis 600-7150 Kbps.
Additional Information:
Your DSL Connection Rate :285 Kbps(DOWN-STREAM), 1040 Kbps(UP-STREAM)
IP Profile for your line is - 5500 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 27.44:18.9:53.66 (SBE:NBE:PBE)
You know the answer, you've got a low speed sync, so low throughput. The profile will have no effect at the moment, your sync speed is determining your throughput. Do the usual checks, eg connect to the test socket, use a MW radio to try and detect any local noise. If that doesn't help, let support know.
coreservers
I notice it's below BT's minimum. these are taken from the test socket. I've mailed support. I did ask support to remove interleaving, to try and improve ping times for gaming, could this have done it?
It's always possible if interleaving was keeping the line stable.
coreservers
Well it's improved the ping times, there down from 43ms to 20ms. but I still cant game because the line's too unstable.  :bawl: :rant2: .
You may just have your answer there. :(
If your line is unstable but you still want low pings (interleaving off) ask support to ask BT to increase your noise margin, It will give a lower sync, which means lower speed but might make the line stable without the ping increase.
Sorry to hear it's gone pear shaped. I guess every line is different. I've got a perfect line, but a old exchange. So interleaving is off, and I'm all ok. How far are you from the exchange? Or have you rebooted the router since the swapover?  :dunno:
coreservers
well called support.
basically due to "banding" I have the choice of high pings and interleaving on or low pings and a 164k throughput, both make gaming impossible. Which is one of the things I asked When I started, would it be better than sky's broadband for gaming, yes was the answer.
I've also found out that now it'll take up to 5 days to switch interleaving back on.
Wonderful  :slap:
You were given an honest answer, based on what was known at that time, namely the state of IDNet's network. What no-one could know, until you were connected, was just how bad your line was.
Did you get  remodulated back to adslmax or you still on adsl2+
coreservers
I did ask to be switched to adsl max, some time ago, but after calling today, I get a mail stating "my new broadband order for ADSL2+ will be done in 5 days time". So I guess if it does come back. I'll have to re-request a move back to adslmax. seems a hell of a roundabout way to go about things
coreservers
no idea rik, no idea. other than a crawling service. I was on adsl2+ then adslmax, now I've no idea, but I keep getting mails telling me new broadband service will be ready in 5 days, whenever I request something.
Well, it's too late for me to talk to support now, I can't really do anything till Tuesday. What's your upstream sync speed.
coreservers
285 kbps 1075 kbps
That suggests a profiled ADSL2+ to me, but I can't be sure. Does your router indicate what modulation it's using?
coreservers
seems now to be getting worse and worse (and ping times are back up to 34ms).
I am a global moderator on a site www.ukdetectornet.co.uk, which is quite photo heavy as it contains archaeological photos etc. Took me 2 minutes just to get logged in
and xbox live wont let me in at all. Which is really annoying as I've just got to a really good mission in red dead redemption!
. tried BT speedtest..... now always failing. speed.io ran after 3 minutes, see below
Getting to the stage I've no connection at all now.
coreservers
finally got a bt test to run!
Download speedachieved during the test was - 56 Kbps
For your connection, the acceptable range of speedsis 50-250 Kbps.
Your DSL Connection Rate :285 Kbps(DOWN-STREAM), 1075 Kbps(UP-STREAM)
IP Profile for your line is - 135 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 16.07:17.86:66.07 (SBE:NBE:PBE)
:eek4:
Quote from: coreservers on May 29, 2010, 09:54:42
:eek4:
135kbps is the lowest profile and would suggest serious amounts of noise or multiple disconnections being seen by the exchange.
coreservers
I fear I've been put on the old circuit that they stuck me on when I first transferred to IDnet. it's acting the same way. that was a datastream circuit, and involved 2 weeks of arguing with BT,  :rant2:
just been off for another half hour.
the disconnects are not being made by me,
I've tried the fm radio, in the test socket etc. the only change was my request to have interleaving switched off. 17070 is perfectly quiet.
The circuit has not been changed, those stats show you are on a ADSL2+ line , when you went back to 8mb they remodulate the line , not physically change the connection.
What you have is noise/disconnects for some reason.
Except recent remodulations back to adslmax had maintained the upstream sync if I recall correctly??? But still it has to be a noisy connection
Isn't that what the BT test shows, though, Steve?
