dvd::rip problem
Started by psp83, May 29, 2010, 22:29:32
I've just installed dvd::rip and all the other stuff it needs, everything seemed to be working fine until it got to the end.
I get this message :
It seems that transcode ripping stopped short. The movie has (a large number) frames, but only (a large number) were ripped. This is most likely a problem with your transcode/libdvdread installation, resp. a problem with this specific DVD.
Anyone else getting this and is there a fix?
Ubuntu 10.04.
Paul this link is old but its the same error
http://forums.gentoo.org/viewtopic-t-427408-start-0.html
There's a few get rounds further down the page
Quote from: Steve on May 29, 2010, 22:44:57
Thanks but no luck, still getting the error.
Going to try Ubuntu Mint 9.10 just to see if its 10.04 causing the error.
mrapoc
I had quite a few problems altho this time its fine
Make sure everything in the bottom half of the wizard is installed such so it says OK etc. but im sure u did this
Quote from: mrapoc on May 31, 2010, 16:34:00
I've checked all the settings and everything comes back green (ok) except for RAR.
mrapoc
codecs etc.?
i installed all restricted extras and medibuntu stuff
