netgear dg834g V4
Started by sobranie, Jun 25, 2010, 16:29:06
How does one change the antenna on this router or is it impossible please?
You actually want to change the physical antenna itself, Rick?  Sorry, I can't help with that, but what appears to be the problem?
No real probs Simon. The netgear antenna is rated at 2db and I have a 12db kicking around and am interested in what I can push out with the extra db.
The local taxi office?  ;D
I'm sure one of the techies will be able to help soon, Rick.  :)
Rick, if you open the case, is the antenna bolted in?
Quote from: Glenn on Jun 25, 2010, 17:40:19
Ahhh!  No screws apparent on the 834 so I presume it's a clip fit and me (hamfisted) and clip fits don't go together.
On the old version of a GT I had it was simply a screw fit
