BT Speed test
Started by BAP, Jul 05, 2010, 06:51:55
BAP
Used to be able to do a BT speed test, but for the last month all I get is error.
Me, or is BT test screwed? :dunno:
It is still working BAP,for me anyway.
BAP
Just reinstalled Java, windows 7 64bit. Same, test error :whistle:
I'm not sure there is any logic that can be applied to that site.
Are you using Firefox or IE?
If using one try the other.
BAP
IE8+Firefox, no luck.
Make sure you only have one install of Java as that can confuse it, updates used to just install alongside an existing install.
Remove ALL via control panel and then visit java.com
BAP
Quote from: Steve on Jul 05, 2010, 07:26:37
BT Speed test Working now :shake:
BT speed test is one of life's little mysteries
It is indeed, it works fine for me now (when it works ;D) but stopped working for a few months after they overhauled it.
