NetWorx – Free Bandwidth Monitoring and Usage Reporting
Started by DorsetBoy, Jul 19, 2010, 09:29:10
This looks rather interesting , will be trying it out later today.
http://www.softperfect.com/products/networx/
Latest version
5.1.2 (Jun 21, 2010)
Supported platforms
Windows 2000, XP, 2003, Vista, Seven, 2008
32-bit and 64-bit
License Freeware
Quote
NetWorx is a simple and free, yet powerful tool that helps you objectively evaluate your bandwidth situation. You can use it to collect bandwidth usage data and measure the speed of your Internet or any other network connection. NetWorx can help you identify possible sources of network problems, ensure that you do not exceed the bandwidth limits specified by your ISP, or track down suspicious network activity characteristic of Trojan horses and hacker attacks.
The program allows you to monitor all your network connections or a specific network connection (such as Ethernet or PPP) only. The software also features a system of highly customizable visual and sound alerts. You can set it up to alert you when the network connection is down or when some suspicious activity, such as unusually heavy data flow, occurs. It can also automatically disconnect all dialup connections and shut down the system.
The incoming and outgoing traffic is represented on a line chart and logged to a file, so that you can always view statistics about your daily, weekly and monthly bandwidth usage and dialup duration. The reports can be exported to a variety of formats, such as HTML, MS Word and Excel, for further analysis.
QuoteKey Features
Clear graphic and/or numeric display.
Usage reports with export to a variety of file formats, including Excel, MS Word and HTML.
Permits close supervision of uploads and downloads.
Works with dial-up, ISDN, cable modems, ADSL, Ethernet cards, and more.
Includes network information & testing tools with advanced netstat that displays applications using your Internet connection.
Scalable to your own modem download capabilities.
Option to notify user or disconnect from the Internet automatically when network activity exceeds a certain level.
Speed meter to accurately time downloads and report the average transfer rates.
Dial-up session journal with detailed information about every session.
Absolutely free and does not contain any adware/spyware/malware.
Lots of info,good graphs etc.
This is an excellent application, the combined information is very useful.
Ping and trace routes without having to go to CMD, and the netsats are great,they really show up the system connections. This could well be a good tool for diagnostics here on the forum.
