connection dropping
Started by Colin Burns, Aug 15, 2010, 14:48:10
Colin Burns
Hi
Can anyone give me advice on why my net connection is being Evil while im playing starcraft 2 as it keep droping me from the game and disconnecting my conversation in skype..
i would check my router logs to see whats going on but i dont know how to check them on the 2wire
any advice please
thanks
Not a 2wire user but I believe the router logs are available via the management console for v4 and v5 and routerstats lite is available also. Any signs of packet loss and high ping times
MisterW
if its v5 then...
DslDiagnostics http://home/xslt?PAGE=J42&THISPAGE=A02_POST&NEXTPAGE=J42
Event log http://home/xslt?PAGE=J17&THISPAGE=J42&NEXTPAGE=J17
Detailed log http://home/xslt?PAGE=J34&THISPAGE=J17&NEXTPAGE=J34
Hope that helps
If you need any help interpreting the logs or stats then post back
Can you see the router while you're playing/talking, Colin. It occurs to me that both activities need good ping times...
Colin Burns
i can and its not losing sync
It would be worth plotting your ping times, then and see if they're jumping about.
