Max rate double current rate
Started by qweezy, Aug 30, 2010, 12:05:03
qweezy
Hi,
This is what I am getting with my 2Wire at the moment.  I never seem to connect higher than 2.2mb.  This hasn't changed over holding sync for around 20 days.
Is the line being capped or something?  Up until this started I had no issues connecting at very close to the max rate.
Thanks.
Modem Type:   Built in modem - ADSL
DSL Line (Wire Pair):   Line 1 (inner pair)
Current DSL Connection:
Down   Up
Rate:   2269 kbs   811 kbs
Max Rate:   5157 kbs   832 kbs
Noise Margin:   12.9 dB   7.1 dB
Attenuation:   49.6 dB   29.8 dB
Output Power:   18.2 dBm   12.5 dBm
Protocol:   G.DMT2 Annex A
Channel:   Interleaved
DSLAM Vendor Information   Country: {46336} Vendor: {IFTN} Specific: {47473 }
ATM PVC:   0/38
Rate Cap:   5157 kbs
Attenuation @ 300kHz:   49.6 dB
Uncanceled Echo:   -7.9 dB   Ok
VCXO Frequency Offset:   0.3 ppm   Ok
Final Receive Gain:   28.3 dB   Ok
Impulse Noise Comp. Tones:   0   Ok
Excessive Impulse Noise:   0   Ok
BT do have the facility to band adsl2+ connections, this seems to occur when there are signs of instability and/or high error rates. The upper limit for your sync would be around 2272 if you have been placed on a banded profile. Check with support they will be able to tell you and advise.
I'm currently on a banded 500 K connection for some reason.
I'm heading back to ADSL1 tomorrow, happy days!
Quote from: pctech on Aug 30, 2010, 14:39:04
500K?  :eek4:
and getting throughput of 350K, its awful.
I'm really hoping I can get in on the FTTP trial and wave goodbye to a line I don't really need and a transport technology that should have been written off as a bad idea.
What, BT write off an upgrade path that will make them money? ;D
qweezy
Soooooo basically there isn't anything I can do about it?
Talk to support, see what they say.
Do as Steve advised, check with support.
I'm terribly sorry for hijacking your thread qweezy, hope you get it sorted out quickly.
qweezy
No worries pctech.
Emailed support and they have requested that BT reset my line, which should happen in the next 24hrs.
Fingers crossed.
Did they whether you'd been banded?
