Increased ping?
Started by psp83, Oct 01, 2010, 11:41:38
Has anyone noticed increased ping times?
I re-synced yesterday around 8am (ish) and ever since my ping has doubled and today its even higher.
over a maximum of 30 hops:
 1    <1 ms    <1 ms    <1 ms  192.168.0.1
 2   113 ms   109 ms   105 ms  telehouse-gw4-lo2.idnet.net [212.69.63.99]
 3     *       86 ms    81 ms  telehouse-gw3-g0-1-400.idnet.net [212.69.63.243]
 4    82 ms    81 ms    83 ms  telehouse-gw5-e4-400.idnet.net [212.69.63.245]
 5    83 ms    79 ms    83 ms  redbus-gw2-g0-1-331.idnet.net [212.69.63.5]
 6    66 ms    67 ms    67 ms  redbus-gw1-fa2-0-300.idnet.net [212.69.63.225]
 7    55 ms    55 ms    55 ms  www.idnet.net [212.69.36.10]
Trace complete.
My usual ping is around 13ms.
I've tried rebooting the router aswell.
QuoteMicrosoft Windows [Version 6.1.7600]
Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
C:\Users\zappaDPJ>ping idnet.com
Reply from 212.69.36.10: bytes=32 time=7ms TTL=59
   Minimum = 7ms, Maximum = 7ms, Average = 7ms
C:\Users\zappaDPJ>
No :red:
Obviously there's nothing wrong here so it looks like something local to you.
Doesn't seem to be any problem here.
ping idnet.net
Reply from 212.69.36.10: bytes=32 time=11ms TTL=59
   Minimum = 11ms, Maximum = 11ms, Average = 11ms
My normal pings are around 13 - 15 ms as you can see from this graph taken by thinkbroadband.com
http://www.thinkbroadband.com/ping/share/db87ab60062db6d488e4959e3f1b0aad-26-09-2010.html
But you can see by the graph below, it started to get higher around 8am yesterday.
http://www.thinkbroadband.com/ping/share/e681f99fa2d24c3264d0b7a88138d499-30-09-2010.html
And doing a trace route to idnet.net today I am getting the following
C:\Users\Paul>tracert www.idnet.net
  2    86 ms    89 ms    93 ms  telehouse-gw4-lo2.idnet.net [212.69.63.99]
  3    92 ms    86 ms    91 ms  telehouse-gw3-g0-1-400.idnet.net [212.69.63.243]
  4    83 ms    87 ms    93 ms  telehouse-gw5-e4-400.idnet.net [212.69.63.245]
  5    92 ms    95 ms    93 ms  redbus-gw2-g0-1-331.idnet.net [212.69.63.5]
  6    77 ms    80 ms    84 ms  redbus-gw1-fa2-0-300.idnet.net [212.69.63.225]
  7    70 ms    71 ms    73 ms  www.idnet.net [212.69.36.10]
Trace complete.
Here are some speed tests
http://www.speedtest.net/result/973966662.png
http://speed.io/pics/3530/1029/speed.io.png
http://www.speedtest.bbmax.co.uk/results.php?t=1285930625&v=11011309
And here's a BT speed test.
Download speed achieved during the test was - 5020 Kbps
For your connection, the acceptable range of speeds is 2000-7150 Kbps.
Additional Information:
Your DSL Connection Rate :6684 Kbps(DOWN-STREAM), 992 Kbps(UP-STREAM)
IP Profile for your line is - 5000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 15.95:20.2:63.85 (SBE:NBE:PBE)
Upload speed achieved during the test was - 822 Kbps
Upstream Rate IP profile on your line is - 992 Kbps
As you can see, the first 3 speedtests are much lower than the BT one.
Anyways, I've emailed support with the above, I did say I would phone them back but not got time as I'm off to the hospital now.
Steve's ping reduced after a power cut, maybe he has pinched some of your margin.  :whistle:
SSK
Maybe the resynch switched you from interleaved OFF to interleaved ON?
(For no apparent reason it did that to me recently)
Sean
Even so it's a bigger leap than you would expect for interleave on.
A bit late, but pings are fine here.
You've been watching the golf as well. :evil:
 ;D
No, I've been studying the ceiling and thinking it's about time we redecorated.
Good to see you back, Rik.  :thumb:
Thanks. Last Saturday I thought I had a could, the rest of the week, I thought I was about to cough my toes up. ;D
Welcome back, Rik,  :thumb:
Better than turning them up.  ;D
