Lost connection
Started by psp83, Oct 10, 2010, 19:24:29
Did you want the half back? ;D
It makes you wonder if the circuit was misconfigured in the first place.
Quote from: Rik on Oct 11, 2010, 16:25:06
Or if everyone is to scared to try reconnecting?  ;)
Conrad
I thought there was a 4 hour SLA on MSOs? Maybe I'm wrong.  I'm certain that BT provide ETRs via ECO, so it would have been nice to hear a better update on the cust-svc number.  The only reason I can think of for such a complete cease of service would be non-payment of a bill  :eek4:
Idnet aren't in trouble are they?  :shake:
No, they're not in trouble. Currently, they are waiting for an explanation from BT of what happened, and what will be done to ensure that it can't happen again. The delay was caused by BT's insistence on sending out two engineers, who took three hours to arrive when the fault clearly wasn't a physical issue, ie IDNet could see all the lines were 'up'. Simon then had to persuade the BT helpline in California to get their fingers out and reinstate the configuration.
BT shoyuld'nt have a helpline in California, they should all be in this countyr to help with our employment and debt problems. :rant2:
It's better than Mumbai, Alf. :)
Quote from: Rik on Oct 11, 2010, 17:50:14
... the BT helpline in California...
Well, I hate to be pessimistic, or judgemental, but...
They were probably trying to get some surf time.
 ;D
Now surf and turf I could understand.  :eat:
Quote from: Technical Ben on Oct 11, 2010, 18:05:16
:rofl:
Maybe they were told the fibres needed cleaning.
I think micro-fibre got lost in translation... :whistle:
Quote from: Rik on Oct 11, 2010, 15:51:37
Useful to know, Zap. Have you told support about the router?
No Rik but if speeds are consistently higher I certainly will do.
Kareha
Seems that routing to World of Warcraft may have gone to pot, prior to last nights outage I was getting pings of around 45-50ms, tonight logged on to raid and Im currently sitting at 363ms, rising to near enough 500ms.  In contrast I am also in the beta for the new expansion and that server is located in California, and Im currently getting between 185 and 233ms.  My server for the live WoW system is located in France.
Here is a tracert to my server showing yet again that once it jumps onto Telia it goes pear shaped, everything was fine until last nights outage:
1    <1 ms    <1 ms    <1 ms  my.router [192.168.1.1]
2    27 ms    26 ms    26 ms  telehouse-gw2-lo1.idnet.net [212.69.63.51]
3    25 ms    26 ms    26 ms  telehouse-gw5-e4-400.idnet.net [212.69.63.245]
4    25 ms    30 ms    28 ms  gi8-27.mpd01.lon02.atlas.cogentco.com [149.6.148
05]
5    26 ms    26 ms    26 ms  te1-2.ccr01.lon02.atlas.cogentco.com [130.117.50
38]
6   120 ms    66 ms    26 ms  te4-3.ccr01.lon01.atlas.cogentco.com [130.117.1.
7]
7    27 ms    26 ms   120 ms  te1-2.mpd01.lon01.atlas.cogentco.com [130.117.3.
5]
8   138 ms   138 ms   138 ms  ldn-b4-link.telia.net [213.248.70.237]
9   141 ms   138 ms   139 ms  ldn-bb1-link.telia.net [80.91.249.77]
0   146 ms   186 ms   146 ms  prs-bb2-link.telia.net [80.91.247.240]
1   160 ms   156 ms   156 ms  ffm-bb2-link.telia.net [80.91.246.184]
It should only be coincidence. Let support have the trace (preferably two or three) and they can check the routing.
My trace shows:
C:\WINDOWS>tracert 80.91.246.184
Tracing route to ffm-bb2-link.telia.net [80.91.246.184]
over a maximum of 30 hops:
  1     1 ms    <1 ms     1 ms  192.168.1.254
  2    13 ms    13 ms    13 ms  telehouse-gw2-lo1.idnet.net [212.69.63.51]
  3    14 ms    15 ms    11 ms  telehouse-gw5-e4-400.idnet.net [212.69.63.245]
  4    12 ms    11 ms    13 ms  gi8-27.mpd01.lon02.atlas.cogentco.com [149.6.148.205]
  5    12 ms    15 ms    14 ms  te1-2.ccr01.lon02.atlas.cogentco.com [130.117.50.138]
  6    15 ms    15 ms    11 ms  te4-3.ccr01.lon01.atlas.cogentco.com [130.117.1.217]
  7    12 ms    11 ms    11 ms  te1-2.mpd01.lon01.atlas.cogentco.com [130.117.3.225]
  8   124 ms   124 ms   125 ms  ldn-b4-link.telia.net [213.248.70.237]
  9   127 ms   125 ms   126 ms  ldn-bb2-link.telia.net [80.91.254.21]
10   133 ms   132 ms   131 ms  prs-bb2-link.telia.net [80.91.247.240]
11   165 ms   145 ms   144 ms  ffm-bb2-link.telia.net [80.91.246.184]
which suggests to me you may have interleaving on.
Kareha
I'll do a couple more, and Interleaving is definately off, my router is showing it as Fast:
--------------------------- ATU-R Info (annex A) ----------------------------
Running Mode            :    G.DMT       State                : SHOWTIME
DS Actual Rate          :  4256000 bps   US Actual Rate       :   832000 bps
DS maximum Rate         :  4256000 bps   US maximum Rate      :   832000 bps
DS Path Mode            :        Fast    US Path Mode         :        Fast
NE Current Attenuation  :    33.0  dB    Cur SNR Margin       :    12.0  dB
DS actual PSDM(C)       : 00000000       US actual PSDM(R)    : 00000000
ADSL Firmware Version   : E.38.2.23
-------------------------------- ATU-C Info ---------------------------------
Also one of my guildmates who is also with IDNet is having the exact same issue as me, very high ping to our server.
That's a slow hop to IDNet, then. :(
Niall
Quote from: Lance on Oct 10, 2010, 23:06:55
Netn00b - if this is your second d/c this week, the first must have been BT working at your local exchange.
Niall, if it is important, you could tether your iPhone to the pc to share the data connection.
See now, this is the logic I need! That hadn't even occurred to me! Bleedin' ell :D
Flickr Deviant art
Leo Tolstoy
ou7shined
  1     3 ms     1 ms     1 ms  homeportal [192.168.1.254]
  2     1 ms    47 ms    44 ms  telehouse-gw2-lo1.idnet.net [212.69.63.51]
  3    45 ms    44 ms    45 ms  telehouse-gw5-e4-400.idnet.net [212.69.63.245]
  4    45 ms    44 ms    45 ms  gi8-27.mpd01.lon02.atlas.cogentco.com [149.6.148.205]
  5    44 ms    44 ms    44 ms  te1-2.ccr02.lon02.atlas.cogentco.com [130.117.50.117]
  6    45 ms    44 ms    45 ms  te8-3.ccr01.lon01.atlas.cogentco.com [130.117.0.61]
  7    44 ms     *       45 ms  te2-2.mpd01.lon01.atlas.cogentco.com [130.117.1.74]
  8   183 ms   156 ms   157 ms  ldn-b4-link.telia.net [213.248.70.237]
  9     *      156 ms   218 ms  ldn-bb2-link.telia.net [80.91.251.14]
10   164 ms   170 ms   186 ms  prs-bb2-link.telia.net [80.91.247.240]
11   175 ms   378 ms   242 ms  ffm-bb2-link.telia.net [80.91.246.184]
Trace complete.
Rich.
Klaatu barada nikto!
Niall
Telia are notoriously poo. I've had nightmare problems with them with two different ISPs and I know others on cable and other ISPs that have the same issue.
Flickr Deviant art
Leo Tolstoy
Kareha
Emailed Support with my tracert, hopefully they can get it sorted :)
Nova
Tracing route to 213-248-127-130.customer.teliacarrier.com [213.248.127.130]
  1     1 ms    <1 ms     1 ms  192.168.0.1
  2    39 ms    36 ms    35 ms  telehouse-gw2-lo1.idnet.net [212.69.63.51]
  3    37 ms    35 ms    35 ms  telehouse-gw5-e4-400.idnet.net [212.69.63.245]
  4    40 ms    33 ms    33 ms  gi8-27.mpd01.lon02.atlas.cogentco.com [149.6.148
.205]
  5    34 ms    36 ms    35 ms  te1-2.ccr01.lon02.atlas.cogentco.com [130.117.50
.138]
  6    36 ms    38 ms    38 ms  te4-2.mpd02.lon01.atlas.cogentco.com [130.117.1.
18]
  7    36 ms    39 ms    37 ms  vl3493.mpd01.lon01.atlas.cogentco.com [130.117.2
.17]
  8   150 ms   154 ms     *     ldn-b4-link.telia.net [213.248.70.237]
  9   147 ms   145 ms   146 ms  ldn-bb2-link.telia.net [80.91.254.21]
10   181 ms   155 ms   153 ms  prs-bb1-link.telia.net [80.91.247.6]
11   165 ms   164 ms   162 ms  ffm-bb2-link.telia.net [80.91.246.182]
12   209 ms   167 ms   164 ms  ffm-b10-link.telia.net [80.91.247.185]
We had this before, it's routing from cogentco to telia, and Blizzard will tell us that it's IDnet that needs to whack the peers to get this sorted out.
sof2er
Noticing the same thing on gameservers for steam games, connection to telia starts at 130+ ms.
 4    20 ms    19 ms    20 ms  gi8-27.mpd01.lon02.atlas.cogentco.com [149.6.148
.205]
 5    20 ms    20 ms    19 ms  te1-2.ccr01.lon02.atlas.cogentco.com [130.117.50
.138]
 6    20 ms    19 ms    20 ms  te4-2.mpd02.lon01.atlas.cogentco.com [130.117.1.
18]
 7    33 ms    20 ms    20 ms  vl3493.mpd01.lon01.atlas.cogentco.com [130.117.2
.17]
 8     *      133 ms   132 ms  ldn-b4-link.telia.net [213.248.70.237]
 9   132 ms   132 ms     *     ldn-bb2-link.telia.net [80.91.251.14]
Presuming that ldn-bb2-link.telia.net stands for telia in london in which case it should be 20 ms and not 130
Can you advise of the URL/IP you are using and I'll run a trace from here to see if the problem is beyond IDNet?
Telia does have a rather poor reputation but since the outage latency into Telia has shot up. My current in-game latency is reading 870ms. I'll do a trace route when I've finished raiding. For the record no one in my group of 25 players is reporting anything higher than 130ms.
  1    <1 ms    <1 ms    <1 ms  Vigor.router [192.168.1.1]
  2    29 ms    29 ms    29 ms  lns2.uan.thn.uk.murphx.net [89.145.254.70]
  3    29 ms    29 ms    29 ms  uan-er1.uan.thn.uk.murphx.net [89.145.254.65]
  4    30 ms    31 ms    29 ms  ge2-6-1.cr1.core.thn.uk.murphx.net [89.145.254.161]
  5    29 ms    29 ms    30 ms  ge0-0-1.tr1.core.thn.uk.murphx.net [89.145.254.130]
  6    30 ms    31 ms    32 ms  xe-11-2-0-18.lon10.ip4.tinet.net [213.200.77.9]
  7    31 ms    29 ms    67 ms  xe-4-2-0.lon21.ip4.tinet.net [89.149.185.237]
  8    30 ms    29 ms    29 ms  213.200.78.238
  9    32 ms    31 ms    29 ms  ldn-bb2-link.telia.net [80.91.247.89]
10    37 ms    38 ms    36 ms  prs-bb2-link.telia.net [80.91.247.240]
11    65 ms    46 ms    61 ms  ffm-bb2-link.telia.net [80.91.246.184]
from an LLU line
