Google
Started by psp83, Oct 12, 2010, 15:06:14
I'm trying to sync all my calendars and just wondering whats the best way to sync between outlook and google calendar.
Currently I've got my iPhone sync'd with google calendar & mail through microsoft exchange, will be doing the same with my iPad later today.
Doesn't matter now, Everything all sync'd  :)
So how did you do it, Paul?
For outlook and gmail sync I downloaded a tool from google that does it all :
http://www.google.com/support/calendar/bin/answer.py?hl=en&answer=89955
iphone / ipad calendar sync :
http://www.google.com/support/mobile/bin/answer.py?answer=138740&topic=14252
Other devices :
http://www.google.com/mobile/sync/
If your going to sync calendars this way on iphone/ipad, disable calendar syncing in itunes as you will get dupe entrys.
Calendar will sync as soon as you load the calendar on iphone/ipad or if you've got push enabled.
