Online photo album software
Started by zappaDPJ, Oct 21, 2010, 18:00:35
I've been tasked to set up a photo sharing database for a client that fulfils the following criteria:
  • Requires a login and has administrator defined user group permissions.
  • Can be skinned.
  • Thumbnails plus a shrink to fit image display with an on-click to show the full size image.
  • Basic text editor for image descriptors.
So far I've spent half a day looking around at off the self packages and I'm somewhat bemused that there appears to be nothing that fulfils that basic criteria. Before I look at gettting something coded I was wondering if anyone here has seen a package that might suit.
Thanks Glenn, that's one I've not looked at. I'll check it out  :karmic:
Mobile me gallery if you've an iPhone or iPad possibly???
MobileMe looks rather shiny but I don't think it's got all the facilities I'm look for. Thanks for the suggestion though Steve. Gallery 3.0 might well fit the bill, I'll be taking a good look at that along with Jalbum. Cheers  :karma:
