Setting up a 2700 for ADSL2+
Started by Jup, Nov 04, 2010, 11:55:33
 ;D
I'd have had to put a comma or two in - old typesetter's rules. ;)
Jup
Hi guys,
Quick update, I have managed to get my details to save ;D What happens now is that when I try to connect at PPP Login page I get PPP error username not recognised. I have tried this 5 times but still no luck. Do I just keep trying until I connect or have I missed something? Again I appreciate your help :)
Cheers
My first thought is to double check that you are entering the correct data for the PPP and also the correct router password. :dunno:
There is nothing else that needs doing from the PPP login page, so repeating more then once isn't the answer
PS do you have a stale PPP session ?
Jup
Hi Kinmel,
Thanks for the quick reply, PPP Login I just use the smae info I use to log into my idnet account, so am pretty sure that is ok. How do I know if I have a stale PPP session?
Cheers
Jup
Hi again,
I got it to work ;D The problem was my username to login to idnet and the one on my netgear router page ended .gw7 and .gw6. Once I changed that it connected straight away. Thanks for all the help. Here are my stats on the 2700..
Modem Type:    Built in modem - ADSL
DSL Line (Wire Pair):    Line 1 (inner pair)
Current DSL Connection:
   Down    Up
Rate:    944 kbs    891 kbs
Max Rate:    1109 kbs    892 kbs
Noise Margin:    6.7 dB    5.9 dB
Attenuation:    57.7 dB    33.3 dB
Output Power:    15.8 dBm    12.4 dBm
Protocol:    G.DMT2 Annex A
Channel:    Interleaved
DSLAM Vendor Information    Country: {46336} Vendor: {IFTN} Specific: {47473 }
ATM PVC:    0/38
Rate Cap:    1109 kbs
Attenuation @ 300kHz:    57.7 dB
Uncanceled Echo:    -17.7 dB    Ok
VCXO Frequency Offset:    -24.0 ppm    Ok
Final Receive Gain:    34.5 dB    Ok
Impulse Noise Comp. Tones:    0    Ok
Excessive Impulse Noise:    0    Ok
It appears to be pretty much the same as my netgear. Is there any tweaks or advice on how I can improve on what I have?
Cheers
Do you have an NTE5 master socket, the type with the removable bottom part of the faceplate? If so, try the router there, plugged into the test socket which is revealed after removal of the faceplate. That will cut off any extensions and internal wiring you have.
Just to make the differences clear, below are both sets of figures
Netgear figures
ADSL Link                  Downstream      Upstream
Connection Speed    1149 kbps      821 kbps
Line Attenuation            52 db      17 db
Noise Margin            9 db              6 db
2Wire figures
Jup
stats from test socket
   Down    Up
Rate:    1109 kbs    896 kbs
Max Rate:    1289 kbs    896 kbs
Noise Margin:    5.9 dB    5.9 dB
Attenuation:    57.2 dB    33.4 dB
Output Power:    16.0 dBm    12.3 dBm
ATM PVC:    0/38
Rate Cap:    1289 kbs
Attenuation @ 300kHz:    57.2 dB
Uncanceled Echo:    -21.3 dB    Ok
VCXO Frequency Offset:    -18.5 ppm    Ok
That would certainly seem to imply that your internal wiring or connected devices are causing an issue. How many sockets do you have, what's connected to them?
Jup
Hi Rik,
I have 4 sockets in the house. 1 Upstairs which does not get used. 1 Test/main socket in hallway with phone connected. 2 in main living room, 1 beside tv with sky plugged in and the other next to my pc with broadband connected.
Cheers
Is there a connection to terminal 3 on the back of the faceplate for the master socket, Jup?
Jup
Nope nothing in terminal 3 just 1 wire in each terminal 2 and 5.
Cheers
Then disconnect all other devices from sockets, put the faceplate back on and check the stats when connected to the master socket, Jup. If that still shows the extra speed, it would suggest a device is noisy. The Sky box would be my first suspicion.
Jup
Ok I think my cordless phone seems to be having some effect on things. Here is the stats with the phone taken out of the loop.
   Down    Up
Rate:    1147 kbs    867 kbs
Max Rate:    1365 kbs    868 kbs
Noise Margin:    6.2 dB    5.9 dB
Attenuation:    57.8 dB    33.3 dB
Output Power:    16.1 dBm    12.4 dBm
ATM PVC:    0/38
Rate Cap:    1365 kbs
Attenuation @ 300kHz:    57.8 dB
Uncanceled Echo:    -18.4 dB    Ok
VCXO Frequency Offset:    -15.7 ppm    Ok
I also tested with sky unplugged and it made very little difference. Anything else that i can try?
Cheers
Buying a new phone? ;) Seriously, keep the phone away from the router, including its power supply, and try orienting it differently.
Jup
Yeah i think i'll buy a new phone ;D Do you think it worth my while asking IDNet to remodulated to ADSL or just leave as is Rik?
Cheers
MisterW
Yep, I would go with trying ADSL1 as Rik suggested earlier. With that attenuation you're not going to get much benefit from ADSL2+ ( in fact the 2700 is only synching at ADSL2 ). A Bit Loading graph might be useful to see, but I'm not sure how you get that on a v6. I'm sure Alan will post the link for you.
As MisterW says, Jup, you're not getting much benefit from 2+, unless you are making use of the higher upload speed. ADSL Max should lower attenuation, so you stand a greater chance of better d/l speed.
Quote from: MisterW on Nov 09, 2010, 17:39:57
V6 Bit Loading is at the bottom of this page
Jup
Ok guys I'll give support a call see if they can help me out with that, I'll update once i have spoken to them. Again thanks for all the help/advice guys  :thumb: :karma:
Our pleasure. Bear in mind that support are very short-staffed today/tomorrow, so you may be queuing a while.
Jup
Ok cheers for the heads up Rik.
Equally, you may not, timing is all. ;)
Jup
Hi guys,
I managed to get through to support yesterday and my line has now been remodulated. I moved the base plate for my phone to another socket away and this is my stats now...
   Down    Up
Rate:    1152 kbs    288 kbs
Max Rate:    1572 kbs    820 kbs
Noise Margin:    7.0 dB    23.0 dB
Attenuation:    57.5 dB    31.5 dB
Output Power:    16.1 dBm    12.0 dBm
Protocol:    G.DMT Annex A
Channel:    Fast
ATM PVC:    0/38
Rate Cap:    1572 kbs
Attenuation @ 300kHz:    57.5 dB
Uncanceled Echo:    -15.4 dB    Ok
VCXO Frequency Offset:    -14.5 ppm    Ok
One thing that bothers me still, my download rate has gone up about 400-500kbs which I am happy about but when I download a file or do a speed test my speed seems to be exactly the same around 88-90kbs as it was before. Any ideas why it has stayed the same.
Cheers
